160 degree thermostat
Old Sep 11, 2003 | 06:43 PM
george_scruggs's Avatar
Smile 160 degree thermostat
I just received my superchip max microtuner in the mail, sweeeeeeeeeeeeeeeeeeeet!!!! Yesterday I received my 16 degree hypertech thermostat. Will the superchip account for the thermostat? Is it going to still cause a coolant temperature too low code to be thrown? Has anyone changed the thermostat and or the superchip that might know the answer to this.
Old Sep 12, 2003 | 03:25 PM
Former Sponsor
Hi George,
I'm soooooo....... glad you asked before you stuck that abnormally cold thermostat in there - please, DON'T DO THAT!
*Never* use a thermostat of less than 180 degrees in these vehicles (or just about any other computer-controlled vehicle), as your power won't be what it could be, and your heater won't work very well in winter.
Your engine will make it's highest peak power at a coolant temperature of somewhere between 200 and 210 degrees - this is why your factory thermostat is 192 degrees, and we recommend that you leave the stock 192 degree unit in place. Take a look at race cars - they try to keep their coolant temps at 200-210 degrees optimally - because that is where best power is made - this is also where you get your best fuel mileage & lowest emissions, by the way.
The only time we recommend anything cooler than the factory 192 degree unit (and then use a 180 degree t-stat) is if you are doing *frequent* drag racing, or *frequent* towing of heavy loads up long grades, hills, or mountains, etc. Otherwise, just leave the stock 192 degree unit in place.
Good luck!
Old Sep 12, 2003 | 05:15 PM
BROTHERDAVE's Avatar
25 Year Member
I made a mistake of putting a 160 in my 5.0 mustang and the heater would not work, girlfriend (now wife) made me put another in. napa auto sells a 180.
