Paging Intel486 / ran over some paint
Hi Intel,
I remember you recommended to me to use mineral spirits to remove paint that was run over.
Well, got some mineral spirits and using a cotton cloth and it's tough in taking the paint splatter.
Does it really take a lot of rubbing to take the freckles of paint?
How do I know if I am putting too much mineral spirits, do I risk any clearcoat damage?
TIA
TIA
Is it a splatter or fine mist? For something like that you can use a clay bar. Clay was originally used by paintshops for overspray, which is why it is still referred to by some as overspray clay.
For bigger stuff take a rag and soak it in the mineral spirits and let it sit and dwell on the spots of paint for a little bit. Then you can carefully rub them off. Remeber to let the chemicals do the work.
It's fine mist, and a few big ones.
Ok.. I'll try again tomorrow. I only worked on a small area today, I'll finish it off tomorrow.
Do risk any damage leaving it too long or putting too much of the chemical?
