Windows cracked and it rained
Old Aug 24, 2002 | 10:04 PM
BamaScrew's Avatar
Thumbs down Windows cracked and it rained
i left my windows cracked and it rain REALLY HARD...my seats and carpet got wet....i used a wet/dry vac and got most of the water up...how can i keep from it smelling and mildewing..im more worried about the foam in the seats than anything....i hooked up a fan to try and dry it out...any other suggestions..thanks
Old Aug 25, 2002 | 09:43 PM
Rockpick's Avatar
Moderator &
My suggestion would be a dehumidifier plugged up, in your vehicle, with the doors closed (window slightly cracked). I think it'll do the trick.
You can rent dehumidifiers at most 'rental' shops.
Good luck.
RP
Old Aug 25, 2002 | 10:05 PM
Intel486's Avatar
As long as you keep the fans in your truck going, then it shouldn't be a problem.
I've gotten seats pretty wet in the past trying to get all the dirt and stains out of them and have never had a problem. I just get all the doors open and have fans going through.
Using the wet/dry vac on the seats probably got a good amount of the water out. You could even go out and squeeze the seats with a towel to soak up some more water.
Keep the fans blowing in your truck and it won't be a problem.
IF you get the mildew stain, then have an ozone machine run in your truck for awhile. It'll kill the mildew.
