Glue Recommendation Needed
Old Apr 6, 2002 | 05:18 AM
Evan Artz's Avatar
After disengaging the parking brake recently, the rubber pad fell to the floor. What household glue can I use to fix this right the first time so it will last another 8 years?
Also, thanks for the tip a few weeks back about using lighter fluid to remove adhesive marks on windows and around inspection stickers.
Old Apr 6, 2002 | 04:12 PM
Navi Man's Avatar
3M makes an adhesive for trim that would probably work. I think it's available as regular and a heavy duty version. Make sure it sets up and has time to dry. I'm not sure, but I also believe the rubber pad has a lip around it to hold it to the metal portion of the pedal. Make sure the rubber pad is completely on the pedal.
Old Apr 7, 2002 | 09:04 AM
J-150's Avatar
good old contact cement is the best bet for matching rubber to metal. If applied properly, it will last another 8 years.
Don't forget to breathe deep for that extra little smile on your face...
Old Apr 7, 2002 | 12:54 PM
Iwao's Avatar
Smile
It might be over kill but I bought some epoxy mix at home depot to fix the broken handle on our microwave. I wasn't sure it would hold up to all the pulling that caused the handle to break in the first place.
I was blown away by how strong it held. It comes in a syringe(sp) with two tubes and if i remeber correctly it came in a couple of different flavors depending on what you were trying to fix.
good luck
Old Apr 7, 2002 | 03:39 PM
max mitchell's Avatar
I'm thinking...spring for a new one...slightly higher than a glue purchase.
