M205
Old Jul 30, 2012 | 11:24 PM
Net Wurker's Avatar
M205
I keep reading a lot lately about how good this polish is. Is it good for use with a DA? I don't own a rotary buffer.
I just take care of our two vehicles, not a pro or anything. I just use the DA about once a year to polish each one, and hand seal/wax them a few times throughout the year.
In the past I used Megs 80 with the DA , yellow Megs pads, (8005 I think), and got pretty good results. My bottle of 80 is almost empty, thought i might try something different.
Should I try 205?
Old Jul 31, 2012 | 01:09 AM
M205 is DESIGNED for use with a DA.
It finishes well enough to be LSP-ready.
Old Jul 31, 2012 | 08:11 AM
Galaxy's Avatar
205 has literally replaced every polish/cleaner in my cabinet; 'nough said!
Old Jul 31, 2012 | 08:25 AM
Net Wurker's Avatar
205 it is then, thanks guys!
Old Jul 31, 2012 | 10:03 AM
dsq3973's Avatar
If the finish of your truck is neglected you are going to need something with more cut to really bring the paint back. And by neglected I mean it's never seen polish before and looks something like the untouched paint on the right side of the picture below.
Old Jul 31, 2012 | 02:38 PM
Net Wurker's Avatar
My truck looks closer to the left side of that panel, so I don't think I need too much of an aggressive corrector. I've been polishing about once a year, for 8 years now. (It's a 2004)
BTW, how often can you polish a modern clear-coat finish before you start getting danger thin on how much clear-coat you are removing? I know factors will come into play, like how damaged the paint was and how aggressive you go after it each time.
But is there a rule-of-thumb, baseline kind of consensus? My truck has had about 8 annual polishes, with M80, no more thant two passes on each panel each time it was done. I am too cheap to buy a paint thickness gauge. Can I still polish it 20 more times or so, and not be in any danger of removing all the clear?
Thanks.
Old Sep 8, 2012 | 10:57 PM
birdshooter's Avatar
Yes, 205 is designed to be used with a DA or rotary, but still can be used by hand.
You might also want to look into Megs New Ultimate Polish which is derived from 205. UP has more polishing oils. Not a pure polish mind you, but does not carry quite as much corrective ability as 205, which is not much to begin with. Both are excellent and both are great as a finishing polish follow-up to Megs Ultimate compound.
