greasing bearings (4WD)
Old May 7, 2001 | 09:16 AM
wildchild's Avatar
Post greasing bearings (4WD)
can anyone tell me how to grease the front wheel bearings in a 4WD truck. looked in the haynes manual but all they had was how to do it on a 2 wd.
truck is a '97 f150 4x4
thanks for the help
terry
Old May 8, 2001 | 01:50 AM
JJ2000XLT's Avatar
Post
'97 & up Ford F150 4x4's have sealed frt wheel bearings & are not serviceable. If they're making noise, you have to replace the bearing & hub Assembly.
JJ
2000 F150 XLT,Reg.Cab,LB,4.6,4R70W,3.55 F/D,Island Blue/Silver,Med.Graphite Int.,Keyless Entry,SRW,O/H console,All Pwr,CC,Ford soft Bed Cover,Sport Steps,Tow Pkg.,CD player,Prem.Cast Wheels
Old May 8, 2001 | 06:58 AM
wildchild's Avatar
Post
thanks much JJ200XLT: no noise yet just figured i should be greasing em soon. guess i don't have to worry about that then.
thanks again
terry
Old May 9, 2001 | 03:53 AM
KYFordFreak's Avatar
Post
Yep, they have the stupid sealed bearing/hub design. Just hope you don't have to replace them. they are about 175 ea for non-abs front wheels and about 214 for abs type front wheels.
Old May 9, 2001 | 07:04 AM
wildchild's Avatar
Post
holy smoke! is that for just the part or is that installed? i suppose they're a PITA to install too right.
thanks
terry
Old May 10, 2001 | 03:01 AM
Post
That is just for the part, and not at a dealer either. I work for a parts store (Advance Auto) and I have priced almost everything on my truck and what it costs to replace. Not sure how hard it is. Might be able to tell you pretty soon. As I have a noise from the front drv wheel, if it's not the brakes it's the stupid bearing. Check chapter * in your Haynes manual, I took a quick glance and think that is the section you need to look in.
PS: If you do need them,check around find the lowest price and then go to Advance, they will match any price on any part as long as they have the same warranty coverage.
