How to remove Carpet in a 97 F150 ?
Hey guys. A few days ago an ******* in a astro fan pulled right in front of me and a bottle of arrowhead water spilled everywhere on the way to work. I wasnt able to clean or soak up the water, i hadto get inside the office. My father owns a professional dry cleaning business and i wanted to know the details on how difficult it is to take out the f150 floor carpet so i can have it cleaned. Its all stinky from meldew and its a nightmare..
Any suggestions would be great.
Thanks guys!
LONG LIVE F150ONLINE
97 F150 Longbed V8 4.6
K&N air filter
K&N FIPK tech MOD & removed elbow silencer
Tires: Yokohama 265/75/16 Geolander AT+
Hyper white xenon bulbs
Bedliner and raven shell
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
Thanks guys!
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
Heya.. that sounds like alot of work!
What if i just cut the carpet in strategic places?
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
K&N air filter
6 disc cd changer
Oil & filter used
Gasoline used
My Truck
To remove carpet:
Remove rear seats (if you have any) by pulling up headrest/back. Unbolt seats and seatbelt. Remove.
Unbolt front seat and center seatbelt.
Both seats and belts use different size torx fasteners. Get a set at the store.
Disconnect the driver seat wires.
Pull out the seats.
Pull up side rails / kickpanel plastic.
Yank out the carpet.
Install is reverse.
Reg cap should take 15 minutes to pull.
Ext cap 30 minutes and some cuss words.
Fritz
Pull out the seats.
Install is reverse.
Fritz
I used to put the carpet in on the assembly line when i was on summer break from school. It might sound confusing, but all you have to do is take up the spots that have been mentioned, and one peice will pull out. Well worth the extra 5 mins or so over cutting it.
Bambino Online
Owners Gallery Truck #179
1999 reg cab/short box/ORP - 3.55; 4.6l 5sp; factory snapless tonneau; twin 6" kicker sub tubes; Custom Exhaust; Mobil 1 5w30/Motorcraft FL820-S
Bambino Online
