cleaning interior
Old Dec 30, 2010 | 06:21 PM
300archer's Avatar
cleaning interior
just wandering what is the best product to clean soy ink off the door it came from newspaper ink the truck is a 2010 any ideas will help thanks
Old Dec 30, 2010 | 09:25 PM
beechkid's Avatar
25 Year Member
For common cleaner...
1. simple green, and a soft brush (tooth brush will work), use a cloth with clear water to wipe/remove any residua afterward
2. For hard plastics- Blue Coral Carpet & Upholstry cleaner (Autozone carries)
3. For fabrics- try either goddards dry clean or KR2 (I'm assuming we are talking fabric- not leather). Both are spot cleaners, spray on, let sit, brush off/vacume when dry (probably the best spot cleaners I know of!
Old Dec 31, 2010 | 12:25 PM
bigsur's Avatar
You should probably add specifics AND pics if you want good help. Ink can be hard to remove. I had some on the interior hard plastic. The only thing that would even touch it is goof-off, but you want to spot test cause that stuff can discolor your plastic. Always try least agressive first...then move on from there.
Old Jan 7, 2011 | 02:48 PM
BLUE20004X4's Avatar
I've heard "Mean Green", made in the USA works. Haven't gotten around to trying it yet, got the spray bottle in the garage for 6 months now- can you say procrastination? Maybe try brake cleaner too, spot dabbing in case it's too much and lifts color, but really I've had no problems with it.
