wiper blade removal???
Break it off, then throw it in the middle of the street and drive over it!!!!
2000 F150 XLT 4.6L V8 Auto, SuperCab, Torreador Red Metallic, Magnaflow Cat-Back Exhaust, K&N Drop-in, Ford Bedliner, Tinted Windows, Steel Horse Billet Grill, Fabtech 3.5" Spindles, 1.5" rear blocks, 3" Body Lift, Lift Lips, 33/12.50/16.5 BFG AT's on 16.5x9.75 American Eagle 589's, Fabtech Performance Shocks, Sylvania Cool Blue Headlights
www.geocities.com/y2kf150
The catch might be jammed, so try pushing the blade assembly away from the truck first, then squeeze the tab and pull the blade back down towards the truck. You can tilt the blade assembly back a ways to give you better access to the clip.
If you can squeeze the clip, the blade assembly should come off. Just keep at it. It could just have a bit of junk in there jamming it a bit.
