Bedrail cap scratches
Old Jan 25, 2000 | 03:39 PM
IKE's Avatar
IKE
Question Bedrail cap scratches
I just had a Line-X liner installed, and after that, the abrasions in the plastic bedrail caps REALLY became noticable. They are not deep, in fact they barely break the surface, but they get a "chalky" white-ish look to them.
Anyway, my question is this, has anyone found a way to hide this? I've tried ArmorAll, and various similiar products, but can't completely get rid of the funky look. You'd think that since they are not painted, when they get the inevitable scratches they would be invisible, but I can't get rid of them!
<A HREF="http://www.inlink.com/~usguys2/f250.html" TARGET=_blank>IKE
2000 F-250 SD CC 4x4</A>
Old Jan 28, 2000 | 07:23 AM
LARIAT1's Avatar
From: INDIANA,.....USA " Where more than Corn grows in Indiana"!!!
Talking
The only way is to replace them or have a local body shop take a look at them. They may have a compound that will out the scratches .. ...Lariat#1
1997 Red/Silver F150 Lariat Flareside 3 Dr. SC..... ORP & Tow Package, Complete Lariat Option Package ,{APPEARANCE} AVS Carbon Fiber Headlite Covers, Tail Lite Slots & Door Sill Protectors,Owens Fg. Step Boards, Tinted Windows,Ford 2-Piece Bra,20" Chrome Exhaust Tips,A.R.E Bed Cover Lid,Pendaliner Inner Tail Gate Protector,Zie-Bart Total Paint & Under Coating W/ Sounder Deadener Protection, #1 Ford Truck Plate under glass on Front Bumper,Custom made Ford Red Window Decals,Blue Tinted Rear Lic. Plate Protector,Blue Billet Valve Stem Caps, Ford Chrome Hitch Receiver Cover {PERFORMANCE} 4.6L WINDSOR Auto, 3.55LS, 4-Wheel ABS,Platinum 3 Spark Plugs,K&N Air Filter W/ modified stock MAF side air box,Custom Cold Air Chamber (Dam) to keep hot air from K&N Air Filter,Tornado Air Man.,WMS Velocity Tube,Dual Exhaust System W/Stock Muffler,Performance Fiction Carbon Metallic Z-Rated Disc Brake Pads,Goodyear Wrangler A/TS Tires,55 Watt Halogen(replacement) Reverse Lites, Pilot 55 watt Halogen (add-on) Reverse Lites on Hitch under truck,Driving Lamps upgraded to 55 Watt Cool Blue Halogen Bulbs,Driving Lamps(Foglites) work W/ High Beams On & Driving Lamps(Foglites) also work (ON or OFF) W/ Park Lamps On W/Switched Relay {AUDIO} Stock In-Dash Cass. W/6 Disc Changer & 4 Stock Speakers,Trenz Billet #3 Antenna {SECURITY} Ford Total Security System W/ Motion Alarm All on factory Key Fob,Ford Warning Decals on Windows,A.R.E Cover & Hood also wired to Alarm System This is LARIAT#1..... IN The Great State Of Indiana "Where more than corn grows in Indiana"...........http://hometown.aol.com/terrylariat1...page/auto.html A Very Proud Member of ...www.f150online.com
Old Jan 31, 2000 | 07:29 PM
nomo's Avatar
Smile
Have Line-X sprayed over them! The stuff is supposed to stick to just about everything.
Old Jan 31, 2000 | 08:59 PM
Bubbadewsky's Avatar
Post
I have had similar problems with scratches in plastic, on shallow scratches use very fine sandpaper to dress them up. On deeper scratches I use a knife to level the scratch then use the very fine sandpaper, if you want a really smooth surface use rubbing compound. After the repaired surface matches the surrounding area use a cloth saturated with motor oil and polish the oil into the repaired area. This may take several applications but after a short time the oil stains the plastic back to its original darker color. Also if you don't want to sand or rub the plastic use a round object such as a deep well socket and roll the socket over the scratch with very firm pressure until the scratch is literally ironed out. Most all scratches can be improved by this method and some can be repaired to like new. Some scratches just dissapear with the oil being polished into the plastic. Be careful if the surrounding area is not smooth (may have engraved look) that you don't make matters worse by sanding the original texture away.
2000 F-150, XLT, SC, 5.4, 4X4, 355 LS, ORP, Black/Silver, class III, single CD, sliding glass, med. gray, keyless, elect. shift, engine date 8-18-99, '93 Harley Fatboy Black & tons of chrome
