Doing 1st detail soon, expert help wanted
Old Jan 22, 2009 | 04:31 PM
ChromeZ's Avatar
Okay so ive done alot of wash/wax buff jobs but never a detail to this points.
Its been a year and a half since ive had the truck. i got it new with like 10 miles from dealer.
This is what i have and plan to do in this order. If order is incorrect or im missing something please let me know, no DA (yet!)
Megs NXT Wash
Clay w/ UQD
Megs Glaze #7
NXT Wax
and follow up with #26 the day after.
also got a bottle of hyper dressing but havnt tried it what application can it be used for. Wheel well, plastic trim, tires? please fill in on all the amazing uses!
I have plenty of microfiber towels, applicators for waxes and things
Truck Condition: Paint is good only minor swirling visible which the glaze and waxes should fill in i assume. Black sure likes to show those swirls close up when its clean
ANYWAY if i missed nething or need to change the order i do something please feel free to yell at me for being a little novice
Banana for those that help !!
Old Jan 22, 2009 | 04:47 PM
esf's Avatar
esf
For what it's worth, Meguiars doesn't recommend using UQD as a lube. They claim it's not cost efficient, but I also remember reading somewhere about the protection it leaves behind causing a problem. I imagine it can cause issues with the steps that follow the claying stage. The point to claying is to remove embedded contaminants and provide a clean surface. If the lube you're using is leaving something behind that is substantial enough to cause water beading, I'd imagine it could also cause problems with polishing and bonding of other products to the paint such as #7. Any of the other Megs QDs are recommend over UQD. Your order is correct though. Everything seems to be over the counter products from Megs so I would also recommend picking up some ScratchX 2.0 (make sure its the 2.0 and not the original) and/or SwirlX, both new products from Meguiars. Because they're new they might be difficult to find everywhere yet. Some have found it at WalMart already though. Anyway, both would be a good step in between the claying and the #7 to remove the swirls instead of fill them and both products are designed to be used by hand.
Hyperdressing is great. It can be used to achieve a matte or glossy finish on tires, wheel wells, interiors, exterior plastics, and it wipes off of paint easily with an MF and QD. 4:1 (4 parts water, 1 part HD) gives a good matte finish, 1:1 for glossy and 2:1 and 3:1 for in-betweens.
Good luck and don't forget pictures.
Old Jan 22, 2009 | 04:52 PM
NCSU_05_FX4's Avatar
Adam's Polishes has a good line of quick how-two videos.
http://www.adamspolishes.com/t-videos.aspx
Good stuff! I know a little about working on a black truck...
Before:
After:
Before
After
- NCSU
Old Jan 22, 2009 | 04:55 PM
4wd150's Avatar
looks good! was that done by hand?
Old Jan 22, 2009 | 05:02 PM
Thanks!
Definitely not done by hand! I feel for any soul who attempts that on a vehicle of this size!
I used a Porter Cable Dual Action polisher and a bunch of Adam's Products, see below:
- NCSU
Old Jan 22, 2009 | 05:14 PM
esf's Avatar
esf
I would really like to see those after pictures of your truck in direct sunlight because in my experience, Adam's doesn't offer much in terms of paint correction. The first picture that shows the swirls is a great direct reflection of the sun. I would have liked to see those same direct reflections on the afters.
Old Jan 22, 2009 | 05:18 PM
This better? It got a little cloudy that afternoon...
I just like the reflection better in the first one I posted. Plus by the time I was done the sun had moved quite a bit so I couldn't get the same angle. I'll try better next time I do full detail because there are definitely swirls in the paint again.
- NCSU
Edited to Add: That's a pic of hood in case you couldn't guess. My biggest problem is water spots more so than swirls. Still looking for something that will get rid of those!
Old Jan 22, 2009 | 05:35 PM
esf's Avatar
esf
It's definitely a reflection of the sun, but I think the clouds take away from it. I fully understand the sun not being available come the end of a detail. They're very time consuming.
Your truck looks great by the way.
Old Jan 22, 2009 | 05:42 PM
ChromeZ's Avatar
very nice pics there.
I have some nxt speed detailer i got froma package i bought from ads a while ago, would that be better to use with the clay? or would you guys recommend something different i could grab/order real quick. looking to do this beginning of next week after i some rain free weather.
Old Jan 22, 2009 | 05:57 PM
esf's Avatar
esf
You can use Speed Detailer since you already have it. Or you could go to any of the major parts stores and pick up some Quik Detailer (not to be confused with Ultimate Quik Detailer). If you don't mind ordering online, you can always get some Meg's Last Touch. At $17 a gallon, it's a great choice for lube. Especially since you dilute it 1:1 for clay lube. So it's like getting 2 gallons of clay lube for $17 that can also be used full strength as a quick detailer.
Old Jan 22, 2009 | 07:26 PM
troberts6874's Avatar
i am confussed....are the steps on the truck are different on the afters??? or is it just me??? the grille is also different if i am not wrong...i see spiderman insert on the before and harley on the after....oh and the wheels also...
Old Jan 22, 2009 | 07:58 PM
esf's Avatar
esf
yeah I saw that too. Still though, at some point in time the truck started looking better. Haha. How much though who knows without real sun shots. I jsut assumed that the first 4 were taken at the same time and he was just showing off the full pic of the truck because it was all cleaned up from using Adam's products.
Old Jan 22, 2009 | 08:48 PM
Correct, all of the "before and after" shots were taken on the same day.
The last picture was taken after a simple wash and wax, but I like that one. Did you not notice the background is completely different in the last shot?
- NCSU
