Plastic wax
Old Jan 6, 2009 | 05:20 PM
poolboy1191's Avatar
Exclamation Plastic wax
So my dad waxed my truck as a suprise for an upcomming event, and he used a power buffer.
Well the buffer slung Wax all over my Plastic running boards, i can't figure out how to get it off.
Is there a chemical that will get the dried wax off without discoloring, or hurting the ABS Plastic?
Old Jan 6, 2009 | 05:24 PM
MmmBuckles's Avatar
pencil eraser
Old Jan 6, 2009 | 06:27 PM
andrewc_11890's Avatar
pencil eraser should work just fine on it like buckles said
Old Jan 6, 2009 | 07:53 PM
MTM Ford's Avatar
Or a Magic Clean Eraser. Those work good also.
Old Jan 6, 2009 | 09:04 PM
Mothers Back to Black. It's total crap as far as making black stuff black again, but it does a pretty good job of removing dried wax.
Old Jan 6, 2009 | 10:09 PM
Blang's Avatar
Griot's makes a dried wax remover, works pretty well, I have used it plenty of times.
Old Jan 6, 2009 | 10:15 PM
Lumadar's Avatar
Meguiar's APC+ is safe and very effective. If you do not have that product in your arsenal already, you should get it. It's amazing.
Old Jan 8, 2009 | 06:24 PM
Proto's Avatar
Creamy Peanut Butter... works everytime. no joke. It also restores the plastic and makes it look brand new.
Old Jan 8, 2009 | 06:42 PM
esf's Avatar
esf
Could you substitute crunchy peanut butter for a diminishing abrasive polish to remove swirls? They make extra crunchy peanut butter as well. Compound?
All jokes aside, I have heard that works.
Old Jan 8, 2009 | 07:22 PM
roushstage2's Avatar
You can save yourself the trouble of getting the peanut butter off and just use peanut oil. The actual oil is what removes it.
Old Jan 8, 2009 | 10:47 PM
Proto's Avatar
the grit in the peanut butter helps I think though.. if you just use a little at a time then it will just wipe off.... like wax. Works perfect.... and its like a dollar.
Old Jan 9, 2009 | 01:48 PM
If it's creamy, there's no "grit?" LOL, don't want to argue or anything over peanut butter, just saying. It is the oil though.
