Boss 330's cleaning help please!!
I have black Boss 330's with a polished lip. My question is, is the lip clearcoated? I have been using polish on it and now Ive been hearing I shouldnt be using polish. Have I ruined the clear coat?
The rims are in good condition but when you look at the wheels in the sun you can see light scratches all over...what can/should I do to remove these scratches.
Also, the black part is painted...what kind of cleaner should I be using for this...I should be using something different than the lip right?
Any help would be greatly,greatly appreciated!
Here is a pic of the wheels...
http://images.google.com/imgres?imgu...G1GGLQ_ENUS301
Is the lip aluminum?
I know on billet aluminum i use NEVERDULL wadding...it chemical saturated and works great. But, if surface is chromed it will evetually eat up the chrome. Again, it's excellent for raw aluminum.
As far as scratched in the lip, that's probably from rubbing on them while not totally free of dirt. Eitherway, only way i know of removing scratches from raw metal would be the route of rouge polishing.
Sorry i can't help with power ball, never used it.
Well, like TazzRider said, it is uncoated metal. My suggestion is Mr. Buffer (www.mrbuffer.com). That stuff is amazing, I have a few bottles in the arsenal.
If you're going to use a powerball on the polished lip, I'd tape off the black parts with blue painters masking tape before hand so you don't hit the black parts with metal polish. Just tape enough off so that the ball doesn't touch any black. Then make sure you clean up any splatter left from the ball throwing product around. Your favorite quick detailer should do the trick for that.
I have the boss 313's similar to yours. The lip is what they call "super finish". The machine that cuts the wheel polishes as it cuts. Basically polished. The whole wheel is aluminum and the center is powder coated. I just use wax on mine. Do not use anything abrasive on the center. I get spots in the lip area sometimes and just use chrome polish by hand to get remove the spots.
