Plast-X?
The term 'scratches' is far too loose to really give you a 'yes' or 'no' answer. Sorry.
What I can tell you is that it does a pretty decent job at removing light oxidation and minor scratching - very minor scratching. When utilized with a 'mechanical application process' (ie: rotary and wool), it's a much more powerful product. By hand, plan on it taking a while...
No, you should not have to do the interior of the headlight assembly.
the product is not very abrasive, so as Rock stated- if they are minor scratches or "smudges" on the plastic lens, you can often remove or make them less noticeable.
I have applied by hand on a bug deflector and to be honest, it wasnt impressive. If applied with a rotary, it came out pretty good.
If they are scratches with some depth that you can actually feel, you may need to wet sand first, then follow up with Plast-X and rotary. Or this may be the excuse you were looking for to go purchase those Lightning headlights (j/k)
