Review: 8 Carnuba Waxes ...
Old Jul 2, 2008 | 07:33 AM
Iam4st8's Avatar
Uhg. fine thump. Just thought i'd let you know that i really wanted to know the difference between these waxes and appreciate your experiment.
Old Jul 2, 2008 | 07:42 AM
leedriver's Avatar
Originally Posted by cufootn
I am leaving for St. Maartin on sunday and when I get back I'll do an opinionated test of my own using #80, SSR's and menzerna SIP.
This is something I've been wanting to see for a while... keep us posted
Old Jul 2, 2008 | 08:44 AM
05_sprcrw's Avatar
Great post thump lots of good info in here. Thanks
Old Jul 2, 2008 | 09:00 AM
gators241987's Avatar
looks good thump. that black is sure shinny. i think you gained 5 hp with those waxes.
Old Jul 2, 2008 | 10:10 AM
Rockpick's Avatar
Moderator &
Originally Posted by ThumperMX113
I forgot to mention earlier. I got to try out another new product. I've always been leary of QDs. I'm starting to use #34 after every wash now, it gives it a little extra shine. So with all of that said, I decided to try out Poorboy's Spray and Wipe. It's a waterless wash. ... Well, of course it got a little dusty today as I was driving. I decided to try it out tonight. I can't tell you how impressed I am with this product. I really wasn't expecting it to work as good as it does. I thought it'd be streaky but it's not the case at all. I used a Pak Shak UltraPlush towel and it worked amazing. I highly recommend it for someone looking for a waterless wash. I have not tried ONR but I hear good praises about it. I'm also going to be trying that once my wallet stops crying from these latest purchases.
As a hint here from someone who has been using this product for YEARS... it is a good product but most will find that you almost always have to follow up with some type of finishing product as it *is* very smeary in most cases. If you weren't getting smearing, you probably weren't using enough of it. Remember, for a product like this - unlike a mist and wipe type of product - you want to use a little bit more of it if you're using it for a higher degree of dust and such. The purpose is to provide a couple of things: 1) lifting action for the dust and crud sitting on top of the paint and 2) lubrication for the towel as it moves across the paint.
Really, IMO, S&W is a HORRIBLE spray detailer product but a terrific product to use prior to using a finishing spray like 4* UGE or M135 or whatever your flavor of finishing spray may be.
Also, and lastly, I would never, under any circumstance, use S&W as a waterless wash... ever.
-RP-
Old Jul 2, 2008 | 10:30 AM
Rockpick's Avatar
Moderator &
Also, another thing...
Why would you want to use Dawn as a clay lubricant? Horrible idea, honestly...
Clay has a natural amount of oils in the mix that are there to serve as a component to keep the clay pliable and also to help hold the matrix together. Using Dawn to clay will diminish and/or eventually wipe out those oils in the clay bar to render it generally useless after a time or two. In short, the clay will begin to break down, become crumbly, and will have to be tossed in the garbage.
I don't have an endless amount of funding to utilize on 'detailing ****' so, I'll refrain from using Dawn and would suggest that most people also do the same. My thoughts on Dawn have changed over the years to the point that I simply do not feel that it's necessary at ANY point in time during a detail as other preparatory procedures will remove anything that is sitting on top of the paint so that you're simply working on the paint itself.
I've heard the argument made that repeated (while I know this isn't a habit) use of Dawn can actually deteriorate the clear in a much more accelerated fashion. This is done by the same principal as the clay -- that being that it's removing necessary oils and emollients that are in the mix and are necessary to keep the clear from becoming brittle. I've heard other schools of thought say that this is bogus but, based upon my reading and a little brain-picking that was done with a few PPG Automotive Finishes representatives (non-body shop guys -- more technical guys), they confirm that the repeated use of highly caustic soaps will deteriorate clears - and even single stage paints - more rapidly.
Just food for thought during a 8-course meal that you're trying to pull together. All of these aspects are critically important to someone coming along and reading your thread thinking that your way is the best way in this particular instance. Not ripping you (loose the defensive attitude already on this one, okay?) ... just pointing out that your paradigm may be a tad skewed here from a preparation standpoint.
-RP-
Old Jul 2, 2008 | 11:19 AM
ThumperMX113's Avatar
#34 does get streaky. I just re-wipe the surface with a clean MF. Well as far as PB S&W being horrible that's your opinion. Just like it's my opinion that it's awesome. The clay was going to be thrown after so it wasn't a big deal to be using it with the Dawn. It's been in the trash since after the little test. Also, I did the Dawn to be certain to remove everything on the surface. I was talking with quite a lot of people and they said that they didn't believe that clay and # 80 would remove ALL of the previous sealant and wax. Thanks for the advice though.
Old Jul 2, 2008 | 11:35 AM
Rockpick's Avatar
Moderator &
Your welcome for the advice, though.
Your opinion is that... your opinion. You're entitled to that and I'll never tell you that you're not. What I will tell you is that there are better ways to skin cats and that you'll soon learn that by buying up thousands of dollars of products so that you can 'test' them in an eight way test-off.
What you're not communicating is the negatives of going through your particular procedures - like the Dawn clay-lube thing. That needs to be said in a well thought-out, more concise, informative post. Remember, you're kind of leading the pack around here so, being overly wordy at times may be a beneficial thing. I'm just pointing this out to the next guy that comes along, knows NOTHING about claying, reads your post and then goes to pumping out your incorrect procedures.
While Dawn *will* remove everything on the paint - for the most part - it's still a bad idea to make it a habit. The next guy may not know that. Again, that's why I pointed it out to the masses that your procedure, while not necessarily incorrect by what you've now posted, wasn't probably the best procedure to go if you're planning on going a little bit farther beyond one clay bar use or with the long term...
It's like my neighbor... he put a coat of NXT on his vehicle (trust me, this guy was lucky to get that on the paint and struggled to spend more than $10 on a bottle of wax)... he then asked me why the wax wasn't there or it wasn't beading after he washed his vehicle with TIDE LAUNDRY DETERGENT... yes, I said Tide.
He didn't know any better... just pointing out the obvious to those who may not know the obvious... No need to get touchy here. If you can't take some criticism, it's time to slow down on the posting because 'the posse' may actually have some good advice that can help.
Old Jul 2, 2008 | 12:41 PM
I gotcha, didn't really think about that when I made the post. This is actually the first time that Dawn has every touched my car. I figured to make the test as accurate as possible, I should wash with Dawn just to make sure it was accurate. Slipped my mind that someone would take is as that is what you should use as a "go to" product for clay lube. I'm not being defensive at all right now Brad but just remember what the "posse" did earlier this week. Anyways, let's not go down that road, we already had one thread ruined because of stuff like that. Like I said before, thanks for the advice.
Old Jul 2, 2008 | 05:52 PM
esf's Avatar
esf
I really, really like both Chemical Guys 5050 and Pete's 53. Both waxes are great, pretty close to the quality of the Souveran. I'm hoping that they'll have a better durability and I compromise and use them routinely on my car. I really can't tell a difference between the two to be honest with you. I, like you, couldn't decide which one to buy. I decided to try them both out and do this test. So, don't worry about it. The 5050 is a great wax !!
I believe Richard posted something about this before but something else you may want to try it Wet Obsession. It's a tweaked version of 5050. I believe the owner of Obsessive Detail is Justin and according to him, when asked what the differences between 5050 and Wet Obsession...
My wax is basically a tweaked version of 50/50. There has been a wetting agent added among a few other tweaks. The durability is going to be pretty much the same, in my opinion the Wet Obsession comes off a lot easier even if it is put on too thick. Also I've had many customers tell me that they get a wetter look with the Wet Obsession.
Durability?
Most people have been getting 6-8 weeks of protection with Wet Obsession. I like to add a fresh coat every couple of weeks, so I don't worry about the durability of it!
From everything I've read, that's about what people have been getting with 5050 as well.
Old Jul 2, 2008 | 06:26 PM
Roush8702's Avatar
I like the concept of this test / comparison.
However I do have some questions/comments etc.
Thump ( sweet looking stang BTW ), you washed with Dawn, clayed, #80'd, then taped. When finished and you removed your tape strip, do you have any photo's then, there should be a brilliancy factor there with wax over just the polish or what did you do to those areas?
Since I know you don’t have an issues with spending money :c) , pick up a container of S100 , I got mine from the local Harley Davidson Dealer so I would assume they all would carry it. $15.00 just do your hood or trunk lid. I would like to hear your comparison on that product vs some of the more expensive carnauba's
Durability on these products I don’t think is going to be as accurate as with a the write-up on the applications/removal ( Your experience with these ) simply because there are too many X factors. For example , your car looks like its garaged ( may not be exposed to the daily elements) as others trucks , is it a daily driver, location ( your in FL way different elements then PA for example) , frequency of wash's ( are they always by hand with the same product ( not Dawn :cP ) or have you ever just taken it to the car wash and used the wand) These are just a few and Im sure this list could go on.
Like I said , I like the concept of this. I would hope that those just getting into detailing or those that were waiting to see the results of different products take it with a grain of salt. The results you wee will vary. If you spend 50+ bucks on a tin of wax and spend the weekend making your truck look new again but work where there is a lot of dust/construction etc then run it through the auto wash with recycled water and whatever bulk soap they buy, your results will vary.
Old Jul 2, 2008 | 06:30 PM
f-150sport03's Avatar
Originally Posted by Roush8702
<snip>
<snip>
I think he is more going after a 'wax A lasts longer than wax B' type of thing, not so much a definitive timeframe... But I could be wrong...
BTW-- in reference to the last paragraph you typed-- anyone who spends $50+ on a wax has no business in a tunnel wash...
Old Jul 2, 2008 | 06:39 PM
Roush8702's Avatar
Your right but you know its going to happen if not with there vehicle maybe the wife / significant other will
Old Jul 2, 2008 | 07:26 PM
Lumadar's Avatar
Well, I have a few grand in products and I still visit my local DIY car wash around midnight or later from time to time. I like it because it is cheap, and I can work in shade, take my time, and have spot free water.
I live at my parents while I finish college and my parents don't want any type of spot free water system installed at their house, so this is the only way I can get access to it.
I never use their brush, or soaps...just the high pressure "wax" for the first rinse, wash with my own buckets etc, and then spot-free rinse.
When it is 100 degrees all day this is a nice way to make sure I don't get ANY spotting with a quickie wash.
Old Jul 2, 2008 | 07:56 PM
Thanks, I appreciate it. It's not the most scientific or even close for that matter but I thought it'd help some people out.
Thanks again. I tried to take photos but even with a Nikon D40X, it couldn't capture the difference between the waxes. I guess that goes to show you how closely these waxes really do look.
Well, actually, I'm not a dry spell for a while. I've GOT to stop spending money, especially when I have more than enough product. Just had to buy a new computer, too. The lightning raped my old one. I've heard great things of S100 though. I almost bought a can of it.
Like F150sport03 said. I wasn't trying to be too technical with this whole thing. Just give people a basic idea of which one is going to last longer. The car is garaged. However it is driven every single day and it sits out in the sun all day long for the most part. It gets driven though the rain, etc. I wash the same way, every single time. Two bucket wash, foam gun, DP Xtreme Foam Shampoo, SM Arnold Lambs Wool Wash Mitt, dried with a backpack blower and followed up with a waffle weave, etc. I'd never take my car to a drive through car wash.
The answers are in bold.
