Water spots
Old Jul 1, 2008 | 08:44 AM
Mower Man's Avatar
Water spots
I washed my 2008 Ford F-150 by hand the other day. I noticed that the truck has what appears to be water spots baked into the black finish. The gray is ok. The water spots are also on the glass. I used a car wash for the prior washes. It was the same car wash I always used with the last black truck. The truck is only three months old and never sits outside. Even at work it is in a garage. Any ideas to clean up the black finish would be greatly appreciated, or is it a job better done by a body shop. Thanks in advance!!
Old Jul 1, 2008 | 08:56 AM
Les22's Avatar
Try claying it as a first step and see how that turns out (before you use additional product). My truck is fine, but my car had bad water spots on the glass and paint. I clayed then followed up with two coats of NXT 12 hrs apart. The water spots were gone, and I believe the NXT will probably provide you with some protection in the future
Old Jul 1, 2008 | 09:25 AM
clay bar is the key. Will make your windshield as clean as it was at the dealer.
Old Jul 1, 2008 | 12:59 PM
f-150sport03's Avatar
And the Lord God Sayeth: "Thou shalt readeth the sticky at the toppeth of thine screen" and then it was, the non-believer read the sticky and had seen the Word. And then all was good.
