Removing pinstriping... Help i may have messed up!!!!!
Old May 31, 2008 | 05:37 PM
polpilot's Avatar
I think i may have messed up... i got this wheel from O' Rileys its like the 3M wheel but cost less... anyways i started to remove the stripes, it was working good then i steped back and looked at it and i kinda got scared... look at the pics, did i? i do plan on waxing it tonight when im done.
Old May 31, 2008 | 05:46 PM
07redf150's Avatar
yikes. is it deep?
can u feel the clear coat gone?
Old May 31, 2008 | 05:51 PM
polpilot's Avatar
idk... i hope not.. i think it may just be the adhesive.... i just seen when i posted this that im sopposed to use low RPMs its workin better now.. but ikd how im going to fix that?
Old May 31, 2008 | 06:34 PM
Copenhagen848's Avatar
It looks like you melted the stripping with high RPMs
Old May 31, 2008 | 06:35 PM
RollingRock's Avatar
I applaud you for not jumping in the CD section in full panic mode....what happens when you try and wipe that "stuff" off? Does it look the same or does it feel tacky like glue?
Skip the finger nail test, run your index finger over the area, what does it feel like? feel like it is raised?
Old May 31, 2008 | 06:46 PM
Gipraw's Avatar
hard to tell from the pic. what do you have in your arsenal to fix this? cleaner wax? scratchX? DA? Rotary?
as RR posted .. what does it feel like? it is sticky, rough or what?
Old May 31, 2008 | 06:48 PM
polpilot's Avatar
It was a combo of melting the stripping and the glue... i up a litte break cleaner on a rag and it came off... IDK how bad for the paint the break cleaner is but i dosnt seem too bad. i dont let is just sit there... wipe it on then wipe it off... bad idea? its working.... i almost have the drivers side done...
Old May 31, 2008 | 06:49 PM
Mach-1's Avatar
First-Put the drill down and back away slowly. Second-If thats just the glue get some lacquer thinner and scrub the sticky stuff off. Third- Get your wifes hair dryer and heat up small sections of stripe at a time. And you should be able to peel it off. It may leave some tape residue, if thats the case repeat step two.
Old May 31, 2008 | 07:01 PM
polpilot's Avatar
Originally Posted by Mach-1
First-Put the drill down and back away slowly. Second-If thats just the glue get some lacquer thinner and scrub the sticky stuff off. Third- Get your wifes hair dryer and heat up small sections of stripe at a time. And you should be able to peel it off. It may leave some tape residue, if thats the case repeat step one.
Well no wife, no Gf for that matter... sore subject... haha so no hair dryer... even if i did i dont think it would work... the striping is cracked so it would come off in 3 million peises... haha... the way im doing it is working.... just talking forever.....
Old Jun 2, 2008 | 07:39 AM
1badstx's Avatar
brake cleaner will eat the paint off eventualy fyi
carb cleaner is a better choice
but i wouldn't recommend it
Old Jun 2, 2008 | 11:28 AM
2stroked's Avatar
Gentlemen,
Lacquer Thinner? Carb Cleaner? Brake Cleaner? We try awfully hard to dispense good advice here. All of those solvents are pretty harsh. Lacquer Thinner in particular will destroy your paint pretty quickly. Let's be careful out there!
Old Jun 2, 2008 | 11:39 AM
stich's Avatar
I pulled the pinstiping of my truck, get this, using my fingernails. Slow process but the easiest on the paint. Then take some WD 40 on a rag and scrub away. Took all the glue off and no damage. Try rubbing alcohol also but be sure to wax after as it takes it all off.
Old Jun 2, 2008 | 11:41 AM
scott1981's Avatar
I second these suggestions
Old Jun 2, 2008 | 12:25 PM
Edit: wrong example shown....
Old Jun 2, 2008 | 12:31 PM
