clay bar and no wash?
Old 04-02-2008, 06:03 PM
Lumadar's Avatar
I use blue myself with no issues, and like mentioned I also use it on my glass. It definitely helps to clay your glass....for sure.
  #32
Old 04-02-2008, 10:07 PM
Rockpick's Avatar
Moderator &
Originally Posted by madmaxwell87
o i know of the knowledge of the elders, especially rockpick when it comes to this stuff so im hoping he'll chime in
**DING** <---- that's a chime.
For my money, I'd stick with the tried and true clay. Blue is one way to go but...
If you have simple overspray (as in a light misting - not globs), the regular clay that you have should do the trick. Remember, you can work an area more than once -- in fact, it's recommended to go over the same area a time or two to ensure full removal.
How serious of a try did you give it the first time?
My 'old' clay typically goes to my windows to finish out it's effective lifespan... one thing stays the same though - if it hits the ground, it's trash.
-RP-
  #33
Old 04-02-2008, 10:50 PM
madmaxwell87's Avatar
no worries i cut it into chuncks as soon as i got it just like the detailing sticky said. i rubbed each spot until it felt smooth with the clay. this weekend ill try it again but im afraid i have more than i thought and it might take a jump to the next level of clay
  #34
Old 04-02-2008, 10:55 PM
Rockpick's Avatar
Moderator &
Lots of lubrication and go after it...
Might be a dumb question but, you're sure this is overspray of some variety, correct? I mean, we're not dealing with road paint or some industrial coating, correct?
  #35
Old 04-03-2008, 12:51 AM
nope,just regular old paint, heavier than it should be cause, well, i didnt mask off as much as i should have, but paint none the less
  #36
Old 04-03-2008, 12:42 PM
glc is offline
If you are going to use the sponge, you need a bucket of soapy water. You have to squeeze the sponge while using it to keep a lubricating film on the surface - and constantly resoak the sponge. If it even starts running dry, you will mar the paint surface.
  #37
Old 04-03-2008, 06:13 PM
could i use quick detailer and just be liberal about it like you do with clay?
Quick Reply: clay bar and no wash?
