Water spots on tinted glass
Old Mar 16, 2008 | 06:39 PM
FF1809's Avatar
Just normal window cleaner doesnt seem to remove all of the water spots on windows, whats the best way to get rid of those stuborn water spots on tinted windows? Afterwards, what do yall use to protect the windows from spoting again? Thanks for all your help. Robbie
Old Mar 16, 2008 | 06:44 PM
azmidget91's Avatar
i use stoners glass cleaner, lots of people here use it, you could try clay baring the glass, then to protect it use regular wax on it (nxt)
Old Mar 16, 2008 | 08:30 PM
ThumperMX113's Avatar
Are you talking about on the inside of the windows? If you're talking about the exterior, you do know that the tint goes on the inside, right? I'd try claying the windows to remove the spots. Waxing the windows will provide protection but I'm inclined to believe that the wax will be gone once you use any type of window cleaner on them. So my advice is to clay bar the windows, clean them with a cleaner like Stoners and when you do wash, just make sure you dry the windows.
Old Mar 17, 2008 | 09:56 AM
Once you get them perfectly clean, RainX might help with protection.
Old Mar 17, 2008 | 03:25 PM
05_sprcrw's Avatar
i have had this problem to on one of my older vehicles, the absolute best way to get rid of the water spots on the outside of ur truck is to use a bug and tar remover and a very very fine piece of steel wool. just apply the bug and tar remover to the window and use a little elbow grease with the steel wool and should have them spots off in know time....
make sure not to do this on the inside of the windows as it will ruin your tint. Hope this helps
Old Mar 17, 2008 | 04:40 PM
.. or just clay it and not worry about scratching your glass.
Old Mar 17, 2008 | 04:56 PM
once you use rainX you have to keep using it, and its gets annoying to have to keep applying it
