Wash mitt, drying
Old Jan 22, 2008 | 05:24 PM
Powercat's Avatar
Originally Posted by ThumperMX113
I like the Meguairs Microfiber mits, I always pick them up in the 3-packs from ADS.
As far as drying, I always use the sheeting technique, a backpack blower, and than the Meguiars Water Magnet. It's the BEST way to dry your vehicle IMO. I can't stand seeing water spots and don't have any problems doing it this way.
I agree with some type of blower as it is a BREEZE! It especially gets all moisture in the cracks... Then blot with Water Magnet...
Old Jan 22, 2008 | 06:06 PM
ThumperMX113's Avatar
.. you're telling me !!
Old Jan 22, 2008 | 09:15 PM
johnnyd2723's Avatar
Originally Posted by RockPick
The flow-dry method involves taking the spray head off of your hose and using the gentle flow of the water to 'sheet' water off of your truck. You're not spraying the truck down but rather using a flow across the paint to sheet it dry. It'll suprise you how much water can be removed by using water.
Blot the remaining areas.
Nice tip, cant wait to try this method
Old Jan 26, 2008 | 02:46 PM
jamieFF's Avatar
Need more info on the 2 bucket method ?
Old Jan 26, 2008 | 03:05 PM
One bucket for soap/water. One bucket for just water. After using the mit with the soap on the vehicle, you put the mit in the clean water and get the mit clean before putting it back in the soap bucket. The whole point is to reduce containments in the soap bucket to reduce the possibility of scratching your paint. A lot of people also use grit guards, just do a search for those.
Old Jan 28, 2008 | 10:59 AM
Powercat's Avatar
I believe this is a post I copied from RP long ago... I copy/pasted into my personal doc.
I will explain the method I use most often.
I start with two buckets, and two chenile wash mitts. one brand new, and the other from my previous wash.
I fill one bucket with water and Meguiars gold class car shampoo .. the other with plain water ..
after getting the truck thouroughly wet, I take the new was mitt, and dunk it in the soapy bucket, and start at the top of the car, washing a small area of the truck, with the size of area based on how dirty the truck is, using a straight back and forth motion. then I will rinse the area.
I then take the mitt and dunk it in the bucket of plain water, and rinse the soap and dirt out of the mitt, including rubbing the mitt on my grit guard.
I will do the top half of the truck using the new mitt, then set it aside (saving it for my next wash, as the bottom half mitt), and use the old mitt for the bottom half of the truck, following the same procedure .. I will dump and refill my bucket of plain water as necessary to keep it from getting too dirty. I will do the wheels last .. then throw this mitt away, or save it for use in a rescue operation..
the idea behind the two buckets and the two mitts is to minimize the chances that dirt, grit, sand, etc will get caught in your mitt, or suspended in your wash water, possibly scratching or damaging your paint ..
Here is a good video on how to wash a car, http://video.google.com/videoplay?do...ch&p lindex=0
