HyperDressing
Old Jan 3, 2008 | 02:09 PM
Skrewd's Avatar
HyperDressing
Does anyone know if any Chain Stores carry it? I looked at Murrays last night with no luck.
Old Jan 3, 2008 | 02:53 PM
f-150sport03's Avatar
I have never heard of it; However, check MOL for the Megs distributors-- there is usually a paint and body shop around that has almost all of the Megs lines...
Also, check for any detailing supply shops around your area.
OR...
You could order from Rick over at ADS (click here)
Old Jan 3, 2008 | 03:46 PM
Rockpick's Avatar
Moderator &
Detailer products are only carried by distributors and other body shop supply-type stores.
You *may* get lucky and find it at a Napa (only because they're getting it through a different supply chain -- and I believe that avenue, which was once open, is now closed).
In a nutshell, check with some of your local PBS supply stores (Paint & Body Shop) and see who is carrying the Meg's line. You can start here:
http://www.meguiars.com/dealerlocator/
That may or may not yield what you're looking for as many resellers will go through another avenue to get the products on the shelf (similar to what I mentioned with NAPA).
Obviously, the easiest way is to order online or call ADS (or any other reseller) direct.
Old Jan 3, 2008 | 04:11 PM
roushstage2's Avatar
+1 for ADS.
