Getting Paint off Paint
Old Dec 29, 2007 | 10:19 AM
RollingRock's Avatar
Originally Posted by troberts6874
3m works great and is designed to work on auto finishes without damage to them.
http://www.3m.com/product/informatio...e-Remover.html
because it is a chemical does not mean it will harm your finish, it is designed just for that, to use on your finish without damage.
If you want to use it....knock yourself out.
To the OP....use the least aggressive method first as described here....if that doesn't work, go more aggressive.
Clay, varying degrees, White, Blue, Pruple, Red
Chemical.
Old Dec 29, 2007 | 11:21 AM
troberts6874's Avatar
thats fine, least aggressive is fine, but why is goo gone or 3m aggressive???
pull the pinstripe tape off the car use...ummmm what??? not a clay bar. 3m or goo gone, it is paint safe....
or better yet, buy about $80 (white, gray, red,ect) worth of clay and see that it will not do the trick, then get the $4 can of 3m or goo gone and in less than 5 mins its gone.
Old Dec 29, 2007 | 12:19 PM
I am not opposed to using chemicals. Did you not see my recommendation of Lacquer Thinner?
But what do I know about paint transfer? Probably not much.....
I have no idea how to get paint off.
Old Dec 29, 2007 | 12:29 PM
f-150sport03's Avatar
I spy something red and round.... On the rolling stool... Its the Red Cut pad!!! My favorite!
I also see those fun SSR's and those freaking sweet towels...
Its amazing what you can see if you look at paint...
Old Dec 29, 2007 | 12:53 PM
Originally Posted by RollingRock
Please disregard this post. Do not take this advice.
i saw this one about you saying not to use the 3m
i did too see the one about the thinner, i guess its safe for only you to use and suggest, someone else brings up an adhesive remover and it should be disreguarded, it is so aggresive it should be treated as battery acid, you said use clay and thats what should be used
so why invest in so much more clay when there is something that will get it done, faster, cheaper, and very easy to do.
Old Dec 29, 2007 | 01:00 PM
Zaairman's Avatar
Cause sometimes faster, cheaper, and easier isn't the right way to do it.
Old Dec 29, 2007 | 01:03 PM
your not talking about the ones on the ground are you???
Old Dec 29, 2007 | 01:07 PM
so what makes an adhesive remover wrong and clay bar right??? because he said it??? he can use it and suggest it, but nobody else can???
Old Dec 29, 2007 | 06:06 PM
There are no MF's on the ground in that shot. The blue MF in the back near the fence was used with Lacquor Thinner then thrown away, that is why it was on the ground....I was done with that one. The yellow ones are not my "baby's" those are bulk 16X16's from ADS....and they are not on the ground. If they hit the ground, they are done. There is one sitting on my stool tray which is clean, clayed, polished, sealed and then waxed if you wanted know.
troberts6874
Yes.
3M stuff is more harsh than you think. There have been many topics here where it was discussed. It DOES have its place but from experince, I won't use it. I have seen what it can do to paint if used the wrong way. So can APC+, Lacquer Thinner, GooGone, Goofoff blah blah blah. Lacquer Thinner was a trick that my buddy showed me....he owns a body shop and uses it for paint correction just like the samples I provided. Can it do damage? You bet. Is it safe to use properly? You bet. Is 3M whatever safe? Sure....
Net is, using a very harsh chemicals can do really bad things to your paint, especially if used on trim pieces where the paint is so much thinner and easily damaged. If the OP wants to do it, great...if you want to do it great...
Beechkid is known to give incredibly bad advice....its a goal in this area to provide as much detail as possible to help those seeking it....When ever someone suggests going off the deep end, we try and walk them off the ledge from makeing big mistakes.
Think about it for a second. You have a new F150...you found this website. You posted a few times etc. You ran through some paint, yet you remember there was a Care and Detail section on the forum you just joined. You see someone say, use 3M or GooGone....you get your towel out and start scrubbing away...next thing you know, you see color on your rag. Now what?
Have a happy new year.
