Scratch Advice *PICS*
Old Sep 26, 2007 | 02:21 PM
  #31
Stumps's Avatar
He can use a color match touch up to fill the deep scratches and then smooth it out with the wet sanding.
Old Sep 26, 2007 | 02:29 PM
  #32
Rockpick's Avatar
Moderator &
The method that was previously mentioned was to simply wet sand them with 2000 though. No filler.
It'll be tough and likely will not turn out as nicely as what a body shop will do for him but, yes... the fill and sand method could be done. I've used it oodles of times on rock chips and such. It's time consuming but, it could be done. My worry is that the angles at which the scratches appear (like around the back corner there near the exhaust) will be TOUGH to disguise in the right light.
I'm not saying that it *cannot* be done but, I am saying that using 2000 grit alone to remove a scratch that is nearly down to (or down to) the metal will not solve the problem. That's all...
Old Sep 26, 2007 | 02:35 PM
  #33
RollingRock's Avatar
I can no longer respond to this thread as I just leaped from our 22 story office bld.
Can we close this thread?
Sometimes I am baffled why people argue with professional detailers and those who also have over 22K posts.
Old Sep 26, 2007 | 02:57 PM
  #34
Dr. Franko's Avatar
Originally Posted by RockPick
The point that you neglected to pull out of my long-winded post was that when the scratch is THROUGH the CLEAR AND COLOR coats, that there is **NO** way to remove it using abrasive methods.
Think about it... it's all the way down to metal or the base coat. How do you remove it with 2000, 1500, hell... 4000 grit without burning all the way through the paint around the area of the scratch down to the metal? Explain that one and I will back off of the subject (mind you, a respray can't be used in place).
------------------------------V----------------------------
if that's the scratch, the bottom of the V is where you're going to have to sand down to, correct? Let's just say for the sake of arguement here that his scratches are, at the bottom of that V, on bare metal. Explain how we 'remove' the scratch other than taking everything around it - the area in parenthesis - down to metal:
----------------(--------------V------------)----------------
You can't.
That was my point.
Wetsanding a car for the purpose of getting the clearcoat flat is perfectly normal, used all the time in detailing and in body work, and is the answer to some problems but, in this case where the scratches are down to basically metal, it is *not* the solution.
-RP-
It is obvious that if something is through the paint sanding is not going to fix it.
Old Sep 26, 2007 | 02:58 PM
  #35
Rockpick's Avatar
Moderator &
Having 22k posts doesn't mean jack-diddly-doo. I mean, the guy who has that many - mind you there's only one - is a total douchebag and really doesn't know his *** from a hole in the ground.
I think he may know a couple of things about detailing but is far and away from being the 'know it all' of the profession. I think that guy is generally long-winded in making a very short point - probably a problem of his - but, he means well.
What I don't think he means is to be abrasive and come off as a *****. I think he was just saying that it's tough to sand out a scratch that cannot be sanded out without removing all the paint around it. That's all. He really was calm about it and didn't mean to ruffle any feathers - although, it may have come out that way.
If it did come out that way, he's sorry.
-RP-
Old Sep 26, 2007 | 03:00 PM
  #36
Dr. Franko's Avatar
Who do you think you are telling people they can't have a discussion because you know best?
Obviously you don’t know enough to know that color sanding a COMPLETE vehicle with 2,000 is common practice.
You are nothing to me, understand?
  #37
Rockpick's Avatar
Moderator &
That was my point, Dr.F. That's all. Sorry to have come across so 'abrasive' (pardon the pun).
The scratches, to me, look as though they're down to basecoat and, as such, no amount of sanding, compounding, urinating, tatertot tossing or electrical engineering work will make them go away...
God. I need a nap.
-RP-
Old Sep 26, 2007 | 03:02 PM
  #38
Rockpick's Avatar
Moderator &
Easy partner. Same to you Rollin'Rocker.
Let's all settle down, enjoy a slurpee beverage, and talk about our high school sports days...
Little known fact -- I'm a fat ***. I played soccer in HS (many tens of pounds ago). I was heavily recruited by several DII colleges and ended up playing for a couple of weeks - until getting cut -- at a DI AA college in Illinois. You guys?
Old Sep 26, 2007 | 03:12 PM
  #39
Dr. Franko's Avatar
Sorry it was not directed towards you.
I enjoy lifting and boxing but was no where near good enough at any sport to get recruited in school.
Old Sep 26, 2007 | 03:18 PM
  #40
Tap the brakes there Dr Franko. I have caveatted many of my posts with my disclaimer. "what works for me may not for others." And yes sanding an entire car is common practice but not from Ford. Custom painters and professional detailers with years of experience....yes. The common DIY'er, not so much.
I find it strange that there a few newcomers here willing to help others and they jump right to wetsanding as the only alternative to fixing problems.
My post wasn't attacking you even though you chose to attack me which is a direct violation of the forum policy. My comment was an observation in which you took personally.
Old Sep 26, 2007 | 04:28 PM
  #41
Zaairman's Avatar
Agreeed.
Old Sep 26, 2007 | 04:32 PM
  #42
Rockpick's Avatar
Moderator &
Originally Posted by Zaairman
Agreeed.
Shaddup... ya damn college kid that still has the metabolism of a 5 year old. It'll catch you... trust me, it'll catch up.
Old Sep 26, 2007 | 04:34 PM
  #43
Zaairman's Avatar
So, my DA is on its way here...
Old Sep 26, 2007 | 04:53 PM
  #44
Does it pain you Zaairman that I have TWO now?
Going to rent it out to F-150Sport for 500 perday but shhhh he doesn't know that yet.
Old Sep 26, 2007 | 06:03 PM
  #45
Favre's Avatar
It pains me.....
But yes, you seem to be correct that the scratch is through the clear all the way down into the paint as well
