Help please!
Old Jun 5, 2007 | 03:01 AM
knighj1's Avatar
WellI think Im going to gowith the duragloss on the wifes car and either wolfgang or meguiars on my truck i just have not decided yet, sstill a little confused about the two, but nebraska and rockpick are going to respond and clear this up for me.
Old Jun 5, 2007 | 03:02 AM
knighj1's Avatar
I also just noticed that with the megiaurs and others there is a sealant and a wax is this not the case with duragloss or is the 951 the sealant?
Old Jun 5, 2007 | 03:05 AM
rustyzipper's Avatar
Duragloss PBA (Polish Bonding Agent) Is similar to an epoxy (A&B) and bonds chemically when it comes into contact with durable polishes. Duragloss PBA will double the durability and protection of polishes when applied prior to polishing.
Duragloss CCP (Clear Coat Polish)
Duragloss CCP (Clear Coat Polish) is a non-abrasive synthetic formula, which gives a "wet look" shine and durable protective coating. Durable to both acid and alkaline washes. Can be applied to the entire vehicle in the sun or shade before removing easily for a high gloss and protective coating.
Or you can use this also. This is what I use.
Duragloss TPP (Total Performance Polish)
Synthetic Polymer/Wax Formula. Super-tough coating forms a protective barrier which protect against acid rain, tree sap, bird droppings and other environmental pollutants.
Old Jun 5, 2007 | 03:14 AM
knighj1's Avatar
Gottcha
Old Jun 5, 2007 | 03:17 AM
I put the 951 Auquawax on dry--mist and wipe then buff to shine with another MF towel. Use this on your rims also. Actually you can use the 951 on everything. I even use it to clean my glass. It's called the KISS method. Keep it simple stupid.
Old Jun 5, 2007 | 03:20 AM
knighj1's Avatar
I went to my local duragloss place yesterday and they had some things but i was not sure whatI was looking for,now i know
Old Jun 5, 2007 | 03:25 AM
Make sure you try the Duragloss first. I think you'll change your mind about trying some of the other products. I wouldn't say that if I didn't expect it to be true.
