Really light surface scratches on an 07.
This car soap works really very well fellas. You should try it, seriously. I have soft water now, but I used it before I had soft water, with excellent results. The water just sheets off. And it's like $5.00 is all. I know they sell it at Walgreens.
The Rain-X Self Dry Car Wash is formulated to save you time and energy by minimizing the job of towel drying your car, truck, van or SUV. The patented technology treats the surface, causing water to simply sheet away, allowing the vehicle to dry with minimal to almost no water spots. Rain-X Self Dry Car Wash generates a high foam solution containing high quality surfactants. After the dirt and road grime is removed your vehicle's shine will be restored. Safe for all paint finishes and clear coats.
Features:
Save time with Rain-X Self Dry Car Wash by virtually eliminating the drying step!
Patented technology makes the water sheet away allowing the car to dry itself without spotting or streaking.
Rich foam Acts Quickly To Dissolve and Lift Off Dirt and Road Grime
Formulated For All Automotive Paint Finishes, Including Clear Coats.
Will Not Strip or Dull Waxed Surfaces.
Contains 21 fl. oz.
Features:
Contains 21 fl. oz.
Originally Posted by dmontzsta
I have had the truck about 2 months, it is an 07. I noticed that there was no wax on the hood (even though they said they waxed it at the dealer). So I decided to clay bar a few of the areas that had "stuck on" bug cuts, road crap, etc...then I waxed the entire hood with Meguiars Caranuba #3 wax. I then took it off and re-applied another coat. Before I put on another coat, I noticed that there was some minor surface scratches at a certain angle in the right light (it is Metallic Silver so it hides stuff well).
Any idea what causes this? I used the softest cloths I could buy. I also wash using the two bucket method. I do not see them on the rest of the truck, just the hood, which leads me to believe it is from the clay barring and waxing. I made sure to keep rotating the clay bar and checking to see if there was contaminents, I also kept switching sides on the towel when wiping the wax off.
Are these light scratches just something you cannot help?
I recently noticed something very similar on my car that I just clay-barred. It looks great for the most part except that with the light shining "just the right way", you can see some light scratches or "marring" in the paint.
I also suspect that this was caused by me clay-barring. I used a weak mix of QEW for lube and I think it might not have been "slippery" enough.
I have a PC and I think that a light polish (SSR1) should remove this light marring. I haven't had a chance to get to it yet though.
I will also be interested in what RP has to say..........
chamios drying will not cause scratches if the chamios is clean....you do not have to avoid touching the car to avoid scratches if it is clean. use a real rotary buffer (varible speed) with a foam pad...you will not hurt pain unless you are a complete idiot. the porter cable da is a good wax applicator not for scratch removal...you need a compound that matches the scratches. if its just very minor swirls from washing or waxing (most common cause for swirls--waxing a car outside with dust coming down onto the paint, it looks clean but the dust mixed with wax is now very fine sand paper). clear coats today are so hard that just touching one with a cloth will not make scratches. but if you got them and they are fine...nothing works like 3m ultrafina on a foam pad on a rotary buffer....you need speed to cut do not be affarid that someone cut the paint of a single stage acrylic 15 years ago using a harsh red rubbing compound on a wool pad...back them most rotary buffers will full out 3-5000 rpms or off...now with foam, there is virtually no heat build up...and varible speed with speed locks to limit how fast full out is....they are almost fool-proof....
3M ultrafina SE best top coat finishing polish for very minor scratches and swirls.
now i will get ready for the zaino and porter cable DA lovers who say thats the best...
i have detailed cars professionally for the last 2+ years and drive only black for daily drivers and have to make mine stand out because my work is always looked at. i have color sanded 10+ cars and can not see a pc da being able to do anything with 2000 girt final sand much less 1500.
If they're fine surface scratches and only on the hood I think this would be a good case for some Scratch-X. Scratch-X definitely has the power to remove little things like that (and bigger) and it's only a hood, that wouldn't take too long to do by hand. I live in Puyallup, chris, not too far from you. The cheapest place locally I've found for Scratch-X is at Walmart, it's like $7.50 or so.
If you really want to keep your truck in tip top shape you should consider a PC or G100 polisher, they can do amazing things for your paint as well as save your arm LOL. I've been working with an air powered DA and an electric rotary lately and I'm just shocked at the difference you can make with the right tools and chemicals.
I swing a Makita 9227 around a lot. I'll still go to my PC when I can simply because of the simplicity, the functionality, and the overall safety of the tool.
The Porter Cable DA is VERY capable of scratch/swirl removal. It does have a limit, however. To date, as a detailer, I've not found too many vehicles where I knew, from the very beginning, that I was going to have to go after the entire painted surface with a rotary.
With the right pad, the right product, and the right technique, you can accomplish quite a bit with a PC... it may not be as lickity split as a rotary but, it's considerably safer, much easier to use, and much easier on the user.
<snip>3M ultrafina SE best top coat finishing polish for very minor scratches and swirls.
2000 scuffs are CAKE with a PC.
Originally Posted by BigFly10
What kind of lubrication did you use when clay-barring?
Mix to the suggested ration for washing and clay-away.
I also suspect that this was caused by me clay-barring. I used a weak mix of QEW for lube and I think it might not have been "slippery" enough..
While the act of claying can cause problems (trust me, the aggressive clay from Meg's will mar the hell out a finish if not used properly), if done with common sense, I don't think you'll really see any problems.
Of course, your bar could have some grime in it that was causing some of the maring. Are your scratches more 'straight line' (like they may be if you were claying) or are they different? More of a spider web look? Classic swirls? Pig tails?
Edited my spelling :o
Originally Posted by RockPick
I typically use #00 or Last Touch as my lubricant when claying. While talking with a couple of Meguiar's employees when I was out there a few years ago for classes, they said that #00 should've really been named "Hi-Tech Clay Lubricant".
Maybe this was just caused by you bringing it in to better light and paying more attention to the detail? I'm just thinking out loud...
Go for it. Let us know how it turns out. SSR1 is a fantastic ultra-light cut product.
Thanks for the tip. What do you think of just car wash soap for clay lube? I switched to this after I noticed the marring using the QEW and it seemed to work a whole lot better. However, I also threw my cheapo claybar in the garbage and switched to a Mother's bar, so it may have been this too. The reason I ask is that I hate to purchase a "special" product just for clay bar lube considering how much is used when doing the entire vehicle.
First, when you say 'cheapo' clay bar, what are you referring to? The only reason I ask is because I don't think I've ever used a bar that I would refer to as 'cheapo'.
As for the shampoo as a lubricant... there's really no problem with that other than it may start to break the clay bar down (pull the oils out of it rendering it a crumbly ball o' goo.) Probably not but, I have ruined one or two bars that way.
That said, I'd explore just buying a bottle of Mother's or Meguiar's Quik Detailer and use that. Obviously, you can use that beyond the act of claying for smudge/fingerprint/light dust removal.
I don't really think so. I am pretty **** with my paint and I would have noticed this before if it had been there. It is fairly obvious under a bright halogen or the sun.
The scratches definitely appear straight line as opposed to spider web or swirls. I am 90% sure that I caused them while claying, I am just not sure how or why. I do, however, remember at times when claying the hood I would feel some 'resistance' as the bar would catch on the surface. The bar would be sliding along and then suddenly 'catch' on the surface. As soon as I switched to the Mother's bar with car wash soap and/or Mother's instant detailer, this did not happen.
Another thing that could've caused it -- I mean, let's cover that other 10% that you left hanging there -- is that they are wash induced scratching, drying induced scratching, wax removal induced scratching, or Quik Detailing induced scratching.
QD induced typically is my worst example. I'm certain that most all of the problems in my paint have come from me QD'ing when I should've washed.... and it's not like I'm QDing the paint after I've driven through rain for four days... it's typically very light dust/road film that I think has been the predominant cause. Maybe even a remnant speck of something on my MF towel... hard to tell and all is speculation. All I know is that it's rewarding to get them all out of the paint and back on an even playing field with most of the rest of the truck.
Thanks for your feedback RockPick, I appreciate it.
-RP-
