removing pinstripes and decals
Old Feb 18, 2007 | 09:28 PM
05FX4SCW's Avatar
Hi all,
I want to remove my pinstripes and 4x4 decals of off my 07KR.
I hate the way the pinstripes look and I think the 4x4 decals look kinda cheesy on such a clean looking vehicle, especially a KR.
Anyways, Ive had the truck for only 3 months and she has been waxed twice with NXT. Anyone have any tips or know anything I should be aware of before I do this?
I plan on just taking my time and maybe using a heat gun if I can get my hands on one. Any other suggestions? Thanks a ton.
Andy
BTW, I plan on replacing the 4x4 decals with a single 4x4 emblem on the tailgate, kind of like what is found on the Dodges.
Old Feb 18, 2007 | 09:33 PM
NASSTY's Avatar
Hair dryer
Old Feb 18, 2007 | 10:14 PM
jhogan20's Avatar
heat is key. once the adhesive gets hot it will peel right off. I took them all of mine too.
Old Feb 18, 2007 | 10:15 PM
OnBelay's Avatar
Heat gun, or seeing as you're in Florida, leave it out in the sun for a couple hours until the surface gets pretty warm, then slowly peel them off using nothing more aggressive than your thumbnail.
Once they are peeled off, 3M makes a great adhesive remover-wet a soft cloth, scrub the area down, and the leftover adhesive/sticky residue will be gone.
Old Feb 18, 2007 | 10:49 PM
built54's Avatar
+1 on the heatgun
Old Feb 18, 2007 | 11:16 PM
Rockpick's Avatar
Moderator &
Heatgun. Adhesive remover for leftover goo. Wax.
Old May 10, 2011 | 08:12 PM
crewster's Avatar
I pulled the pinstripes off the bed of my '06 slowly and it pulled up some of the clear coat. How do I fix this without expensive body shop repair?
Old May 10, 2011 | 09:53 PM
MI02SVT's Avatar
go to an autobody supply store they have rubber wheels that go on a die grinder might work on a drill not sure basically works as an eraser and youll have them off in no time without messin with heat or peeling off slowly theyll know what your talkin about when you tell them you want to remove your pinstripes
Old May 10, 2011 | 09:55 PM
MI02SVT's Avatar
how much clear did it peel of chunks of it or what happened any pics would be great
Old May 12, 2011 | 05:08 PM
crewster's Avatar
Ok, here are some pics.
http://www.flickr.com/photos/62784953@N03/5713724359
http://www.flickr.com/photos/62784953@N03/5713724937
hope this works.
Old May 13, 2011 | 09:01 PM
MI02SVT's Avatar
nope didnt work
Old May 17, 2011 | 08:28 PM
crewster's Avatar
Please Bring Up My Post
Old Oct 17, 2012 | 08:58 PM
crewster's Avatar
I used a rubber wheel made by 3M just for this purpose. You install it into your drill and run it back and forth on top of the pinstripe. Works like a charm. I used it on the rest of the truck without a trace. I discovered this wheel only after I tried to manually peel one section of pinstripe which caused some of the clear coat to peel. The 3M wheel caused no damage at all. Just be sure not to hold it in one place to long. The rubber wheel is tan in color. I don't remember the exact name, but picked it up at either Auto Zone or Advanced Auto.
Kevin
Old Oct 30, 2012 | 05:07 PM
eizzle's Avatar
Plain 'ol lighter fluid will make quick work of the adhesives and it won't hurt the paint.
