Bird poop - Acid rain etching.
Old Jan 14, 2007 | 10:38 PM
rustyzipper's Avatar
Bird poop - Acid rain etching:
Any recommends for a paint cleaner to take care of this problem? I've been reading about this Meguiar's product (below) and I am familiar with using a power rotary buffer. I'm just not sure what type pads/wheel to use for clearing up clear coat etching. This Megs seems to be the right choice, but I'm not really sure. Thoughts?
I'm not apposed to using a professional in this case either.
Heavy-Cut Cleaner removes deep swirls, scratches, severe oxidation, alkaline and acid rain etching. Diminishing Abrasives™ cut quickly, then reduce to a polishing rouge, while Buffered Abrasive™ action lubricates the finish to prevent scratching.
Old Jan 14, 2007 | 10:54 PM
Rockpick's Avatar
Moderator &
Here's an EXCELLENT write-up on spot removal. Use this procedure for both bird bomb and general water etching as they'll be nearly the same type of defect.
-RP-
Old Jan 14, 2007 | 11:09 PM
Thanks RockPick, I really appreciate it. This forum is great. Great people, great info.
Thanks again buddy.
Old Jan 15, 2007 | 06:39 AM
Rockpick's Avatar
Moderator &
No problem... I'll be up your way late this month or early next to do some work over in South Bend -- I'll be swinging by Politos there in Mishawaka (across the street from Lowes).
Old Jan 16, 2007 | 02:37 AM
Good to hear RockPick. I love Polito's. Arguably, the best pizza you will find in Mishawaka. That's saying something too, given all the pizza eateries here.
