Microfiber towels and carnauba wax.
Old May 28, 2006 | 09:42 AM
bob1's Avatar
I read on another website not to use microfiber towels to buff out carnauba wax because it strips the wax off. I seem to get good results using microfiber towels with carnauba wax. Any opinions?
Old May 28, 2006 | 09:43 AM
mountaineer02v8's Avatar
In my opinion I'd say "Don't believe everything you read on the net"
Old May 28, 2006 | 11:35 AM
Rockpick's Avatar
Moderator &
Ehh... if you want to look at it from this angle -- my opinion would be that using ANY abrasive technique to remove a product will, in turn, remove some of the film build that you're trying to put on the paint.
I will, however, wait for someone to reply to how to remove a product from a painted surface without the use of an abrasive technique... Honestly, the comment that you mentioned is ludicrous.
Old May 28, 2006 | 01:53 PM
bob1's Avatar
When i read that comment, it sounded odd. I use microfiber towels from the recommendations of people here and get good results.Not being an expert, i wanted to get other forum members thoughts.
Old Jun 3, 2006 | 12:22 AM
f-150sport03's Avatar
If anything, MF is better. It is simply more fibers in the same space. Ie: The difference in sandpaper and glass. Same stuff, just some is a whole lot nicer to rub against.
Basically what I'm tryin' 2 say is that MF is nicer than silk. Terry cloth and T-Shirts are MORE abrasive.
It's just physics.
Old Jun 3, 2006 | 01:05 AM
BLUE20004X4's Avatar
The microfiber cloth is a good final buffer, and in Nanowax use, a wax remover. No issues here other than it sticks bad to dry skin. It is forever getting caught on dry finger cracks. I guess I should moisturize, but nope, that is kinda homo for a guy. Final thaught, they are good and I recommend, leaves no haze.
Old Jun 3, 2006 | 01:04 PM
I'm with you. (I'll just assume that what you say about nanowax is true, as I never have used it.) The rest...yep
