help
Old Jan 3, 2006 | 01:46 PM
quicksilvertex's Avatar
help
ok i dont know if im in the right area but does ne1 know how to debadge a truck i want to take off all the ford and f150 emblems on my truck but not to sure how to any help would be great thanx in advance
Old Jan 3, 2006 | 01:49 PM
Rockpick's Avatar
Moderator &
It's simple. Heat them up with a heat gun or similar and then slowly pull them off...
Be aware though that there are mounting holes behind them!!!
Old Jan 3, 2006 | 01:51 PM
2stroked's Avatar
Heat them up carefully with a blow drier, then use a piece of fishing line to "saw" through the softened double backed adhesive layer. You can also pry gently with a plastic (non-marring) tool to get them off. You will find that there are holes in the sheet metal used by pins on the back of the logos to align them properly. So, if you're thinking that you can simply remove them and have a plain surface, you may have a problem.
Old Jan 3, 2006 | 01:53 PM
2stroked's Avatar
See, great minds think alike!
Old Jan 3, 2006 | 10:32 PM
how would i fill in the holes bondo or what else could i use
