Calling clay EXPERT (a.k.a. RP and boss.)
Calling clay EXPERT (a.k.a. RP and boss.) ANOTHER problem! *edited*
I am going to clay my truck this weekend, but I have a quick question. Is it similar to waxing? "Clay on, Clay off?" Or does the clay not come off onto the truck? Thanks.
After using a lubricant of good quality and claying the vehicle, there will be a residue leftover that will come off with a quick wash. Make sure you get the right grade clay. A harsch grade of clay will leave markings in the paint (especially on black or dark colors) and require buffing to remove. White is obviously the easiest, as it shows less errors in the job, but more crap thats on it to begin with.
Best of luck with it, and BE PATIENT, its a long process
Originally Posted by rta108
What would be a good mild grade of clay for new paint with a minimum of contaminants? For a rookie?
In my opinion, the Mother's Clay kit or Meguiar's Quik Clay kit are both very mild and user friendly... Both of these 'kits' come with a bottle of lubricating spray (typically a QD product of some sorts) and also a clay bar.
Once you get your clay, cut it into a couple of pieces. The reason for doing this is to avoid ruining all of it when you drop it on the ground... it will happen, it's just a matter of time. By having two pieces of clay, you can toss the one you just dropped on the garage floor that picked up several sand particles and thus, help to eliminate another factor that could cause major problems when you're claying... ie: a grain of sand stuck in the bar, at the wrong moment, can induce hell on your paint that will involve much more than a little elbow grease to remove. Better safe than sorry... especially on black.
There are others out there and some manufacturers do sell mild and aggressive versions of their clay... From my experience, and several others here, the majority of the commercial clay kits (like the ones you could pick up at AutoZone or similar), are pretty good and should work... even on black.
RP
I discussed the grades one day with RP, and the commercial product I use is color coded differently than the versions available to you at retailers. For instance, I believe it was blue was my light clay, where gray was RP's light clay. I am going up the road to advance right now to return some stuff, I'll look at their products and see if I can't figure out which one is right for you
Originally Posted by deltascrew
Orielly's and auto zone have them Localy here. I bought the Meguiars and it worked really well (rail dust removal )
the box looks like this
...snip...
...snip...
