Door Window Trim
Old Apr 25, 2005 | 10:51 AM
115buffalo's Avatar
Door Window Trim
Can anyone give me an easy technique for removing the trim at the bottom of the door windows on my '97 F250. It is rigid, and I don't want to break it. Thanks
Old Apr 27, 2005 | 02:05 AM
kcward's Avatar
If you are referring to the belt moulding, I think it will come off if you pry straight up, starting from the rear of the door. There may be a small nut holding it on, that will need to be removed first?
You may also have to remove the side mirror first, as the moulding either inserts into, or under it.
Old Apr 27, 2005 | 07:16 AM
Rockpick's Avatar
Moderator &
My understanding is that it pulls straight up and off...
Dufunnel (his screen name) replaced his window moldings with Lincoln Blackwoods moldings several years ago... you may try contacting him.
RP
