SudsBlaster Soap Nozzle
Old Dec 8, 2004 | 08:28 AM
chroma's Avatar
I received some information about this product in a detailing newsletter from CMA. It's called the SudsBlaster Pro Soap and Rinse Nozzle. Has anybody tried this yet? It looks good in that you are able to use your own soap.
http://www.properautocare.com/suprosorino.html
Old Dec 8, 2004 | 09:18 AM
Rockpick's Avatar
Moderator &
I've seen them but have never used one.
My personal feel is that you're still going to have to 'wash' the vehicle to remove the grime and dirt. A water hose isn't going to be able to generate the pressure needed to 'dislodge' grime and dirt from the paint IMO.
Now, if they could make that soap resevoir a long lasting hard water filtration unit of some type... I think they'd REALLY have something.
RP
Old Dec 8, 2004 | 10:44 AM
WildmanNP's Avatar
Thats neat,its like the Mr Clean setup but with out the filter.I was thinking about putting a larger filter in line on the water hose to filter the hard water,the one on Mr Clean is small and needs to be changed after few washings if you have hard water .
Old Dec 8, 2004 | 12:49 PM
japickar's Avatar
Why not just get a mr. clean? its the same price and it has the water filter on it that really does (to my surprise) leave a spot-free shine.
Old Dec 8, 2004 | 01:23 PM
chroma's Avatar
Can you use your own soap in Mr. Clean? Some people have said they were advised against using their own soap in there because it might clog up.
Old Dec 10, 2004 | 08:40 PM
pawj112's Avatar
I don't think there would be a problem with other soaps clogging up. I thing the mr. clean soap is supposed to sheet water off, to aid in the air drying. Honestly any soap would most likely do the trick.
Old Dec 11, 2004 | 09:04 AM
honestlarry's Avatar
after all the talk about mr clean i have bought one the price is
ok but the refills are high. imo
