loose antenna
Old Jul 9, 2004 | 11:39 AM
lrhogfan's Avatar
loose antenna
I have a loose antenna and would like to tighten it back up. I have tried to pry it up, but am a little nervous about messing something up. How do I do this?
I am thinking about just taking it to the dealer and let them do it.
Old Jul 9, 2004 | 12:00 PM
sveach's Avatar
My antenna just screws into the black base, like a regular screw. Are you talking about the antenna itself or the base?
Old Jul 9, 2004 | 12:53 PM
Rockpick's Avatar
Moderator &
Same here. Can you be more descriptive?
Old Jul 9, 2004 | 01:09 PM
lrhogfan's Avatar
If I were to walk up to the truck and grab the antenna, It will easily move around a little bit, that is with it screwed tightly to the base, so the base is a little loose. I know there are screws underneath and I wonder if these have come loose or what?
Old Jul 9, 2004 | 11:34 PM
Bartak1's Avatar
If the antenna mast is screwed in tight then it must be the screwes undernieth like you said. There are 3 of them. Just pop off the black textured plastic piece(its a PITA to get off-i put a scratch in my truck doing it) and the screws are right there.
Old Jul 10, 2004 | 08:42 AM
Hunt4Fun's Avatar
I just took mine off. Find a nice thick soft towel (I used the ones that I dry with) and use that as a pad to protect your truck. The antenna base cover sits on top of the base. There is a small crack where the cover meets the base. Use a small slotted screwdriver and work your way around the cover lifting slightly as you go. Eventually, mine popped off and I could see the 3 screws that are probably loose on your base.
Hunt4Fun
Old Jul 10, 2004 | 02:35 PM
lrhogfan's Avatar
Thanks guys, I actually did it yesterday. Like you said, I used a towel to protect the truck. I wish that I had a new cover to put over the base, but I don't. It is a lot tighter now and I know what to do to fix it in the future.
THANKS
