A/C problems...HELP!!
Old Sep 14, 2003 | 10:54 AM
chonky150's Avatar
Hi,
I just noticed that my A/C when set to the coolest setting will blow cold air for a few minutes and then blows hot air. Another thing I noticed is that when the cold air is blowing and I am at a stop, it immediately switches to hot when I take off. I am also unable to switch to hot/cold on the temperature selector. Does anyone know what may be causing this? Any info would be greatly appreciated.
Thanks,
C
Old Sep 21, 2003 | 10:59 AM
markar2's Avatar
Chonky,
First off what year is your truck? The A/C blowing cold then hot - it could be low on freon or the clutch is going out. When the engine is running at idle with the A/C on - does the compressor clutch cycle a lot or does it stay cycled (on)? As far as your temp selector goes - if it is vaccum controled - there is probably a leak somewhere. If it is cable controled - the cable has probably come off of the mounting point for it has broken.
Mark
