Changing Headlight bulbs
Old Mar 4, 2003 | 08:02 AM
angus's Avatar
Question Changing Headlight bulbs
I received my new bulbs but it looks like i have to remove the radiator overflow canasiter to install the left side is this right.
Old Mar 4, 2003 | 08:20 AM
Rockpick's Avatar
Moderator &
No... not correct. Very common misconception.
First, I would recommend reading your manual. It shows how to remove the bulbs. (I'm assuming that you have a 97+)
There are 'tabs' above the headlight assembly that you simply LIFT UP on and the entire assembly will come right out. Here's a hint too, remove your corner assemblies (held on with one bolt in the compartment)... this will make reinstallation a breeze.
Enjoy the new bulbs.
RP
Old Mar 4, 2003 | 08:38 AM
angus's Avatar
Talking
Thanks i was trying to go through the back side.I looked it over and see what you were telling me Thanks a bunch.
Old Mar 4, 2003 | 08:44 AM
Rockpick's Avatar
Moderator &
No problemo... I tried to do the same thing the first time I pulled my bulbs... very common problem...
Trust me on the recommendation to remove the corners... it'll help a boat load.
RP
Old Mar 15, 2003 | 08:08 AM
PatsF150's Avatar
I put in a set of Sylvania Silverstars last weekend and had a heck of a time getting the headlight assembly out. Even with removing the clear corners. I couldnn't figure out why they were so hard to remove. I ended up moving the rad overflow tank to put the new bulbs in.
Old Mar 15, 2003 | 09:37 AM
Rockpick's Avatar
Moderator &
Removing them for the first time is definately a major PITA. It's a learning curve...
I should mention that the first time I yanked my assemblies out, it took me about 4 hours. LOL
I've had mine out, at least, 10 times so, I can just about do it in my sleep now.
You'll get the hang of it.
RP
