CB antenna
I personally went underneath the cab, on the drivers side of the pickup, you'll find some small rubber plugs, oval ones and round ones. take these out, push the coax up into there. Then open your door, and take out what i call the door "sill." Do this by prying up on it gently on the front of it. you should then be able to see you coax. you can then run it under the front corner of your carpet and then you'll be up around the back of the dash and you can then route it wherever you want.
