New Spray In
yes, they did spray the underside.
He told me but I can't remember. I have his info if anyone is looking into starting this spray business on there own.
His name is Tyrel Swopes - 509-254-3953 - w_swopes@yahoo.com
Here's some info on Xtreme:
Xtreme and Ultimate Linings merged a few years ago and thus dealers have several products to offer. The only one I would recommend would be Xtreme HP. Do not get Grip-It or any of their low pressure products.
Xtreme HP is aromatic which means it will fade if exposed to the sun, but that may or may not be important to you.
Looks good.
But they spayed the two plastic drain plugs in the front. Are they a permanent part of the bed no, or can you take them out if needed. Also do you know if they also filled in the drains in between the floor and the front part of the bed.
Those drains are great when you are cleaning out dirt and debris from the bed.
I told him to go ahead and spray over the plastic drain plugs, I can still remove them if need be. And The drains in the floor were missed he filled them, sprayed and then removed the filler.
Also, I had a rubber mat that I threw in over the top of the new spray in and its works great. Double the protection
Nice that you can pull those rubber plugs out. It stinks they covered up the ones in the floor. I never had a truck with those before and it's great when cleaning out the bed.You'll just have to park up hill when washing it out. Not a big deal.
