3rd brake light wire for camper shell
I guess Ford could have wired a socket in the bed for you to plug everything into, but since most trucks will never get a cap put on them that would be an unnecessary added expense that would overinflate the price of our trucks in materials, warranty, labor costs, etc. Bravo to Ford for keeping it simple.
And the reason for stopping the wire at the door or under the hood in later models is because some of us wire the camper shell for accessories that are only used on the camper shell. Instead of running wires all the way down the underside of the truck, mine enter at the front of the camper shell and are wired to the camper shell. When the camper shell gets removed, so do its wires. If Ford had run the wires all the way back, I would have had to run another wire back up to the front of the bed. This uses less wire and is much simpler than wiring back to the tailgate then up into the camper shell.
I think the more pertinent question is, why don't camper shell manufacturers wire their shells to accommodate all the installed lighting accessories?
Again the most obvious answer is so that we the consumers have options about how we want our toys wired.
Just because your cap has a dome in the back doesn't mean they are all like that. Some shells have a dome in the front.
Plus, some people want their camper dome on a switch in the cab and it's simpler to run the wires from the front to the back once, instead of from the back to the front for a switch then to the back again.
It's still easier to go from under the driver through the firewall to a switch then back out to wherever. Your way would cause me to waste 2X the bed length's worth of wire.
Ford agrees with me.
I've never seen a cap with a 3rd brake light that didn't also have a dome light. But then, I haven't seen every cap made.
So for someone wiring a dome light and a 3rd brake light, I still maintain that the wiring is simplified by going in through the front of the cap instead of the rear. You're going to be in there to tighten the clamps anyway, so I've found that's the most convenient way to route all the cap wiring as opposed to a hot wire in front and the brake wire in back.
It is a good thing in my opinion for Ford to continue to do it how they are doing it. At least that wire is easily accessible and it allows both of us to route the wiring however we want it. Freedom is a good thing, and you are free to disagree.
So when you say you "tried all 4 wires on the cap", You mean you just powered up each one by one? Have you ran a ground to the brake light as well? My shell only had 3 wires because the grounds for the brake light and dome light were tied together in the shell but I could see that some would have 4 if the grounds were separate.
