Bedliners, Caps, Tops & Lids
F150 Cargo Management System?
Old Feb 14, 2010 | 02:09 PM
seanwarm's Avatar
I have seen pictures of this system on this web page and a youtube video. The ford dealers in my area have no clue. Ford dealers can find the bedliner which mentions it is a part of this sytem, but no system. It appears the 2009 6.5 bed has the mounting holes. Where can I find this system? Thanks
Old Feb 19, 2010 | 12:24 AM
F150Light's Avatar
bump. I would like to know also.
Old Feb 19, 2010 | 06:41 AM
mete's Avatar
I have the CMS , but I hadn't ordered it , it came with the truck I got off a lot. The bedliner is for the most part a cut down standard liner and you can cut a standard one to fit .I got the cut down one. I'm not sure I'll get much use from the system.I do have a Diamondbackcover which has a door front and another rear .I use the partition of the CMS to separate the front and back sections. I haven't seen any info about how to use it so you'd have to be creative and adjust things to your needs.
BTW the Diamondbackcover was said to be installed without mods but I found that the CMS was in the way. I had to remove the CMS ,first removing plastic rail covers,modify it [cut notches] and replace it [PITA]. Otherwise the cover is convenient for me.
Old Feb 19, 2010 | 08:55 AM
radar's FX4's Avatar
i would try 4wheelparts. they have everything and guarantee the lowest price. it came new, my cargo ms in my 2008, don't use it much though.
Old Feb 22, 2010 | 11:10 PM
Tungstontiller's Avatar
I have priced the pieces on Tasca parts.
I have kicked around the idea of retroing it to fit my 07' w/ nut certs.
However, I'm leaning towards using uni-strut that has the same dimensions as Nissans CMS. So I can attach Nissans cleat tie down.
Old Mar 11, 2010 | 06:03 PM
seanwarm's Avatar
@ mete - I should have ordered a truck new instead of buying one off the lot. In the meantime it appears I will wait about two years until the Ford Parts Department catches up. Thanks to all for their input 8-}
