Truck Bed: Is it clear-coated?
I want to use "liquid sandpaper" on my truck bed, however I was told that the liquid sandpaper would not work on clear-coated beds. Does anyone know whether the 2000 F-150 has clearcoat on the bed surface? I want to prep the bed for Herculiner. If it isn't clearcoated, I will use the liquid sandpaper to degloss bed prior to applying bedliner.
thanks, Jeff
thanks, Jeff
Jeff,
YES...your truck bed is clear coated. As labor intensive as it may sound, scuffing it w/some 100 grit sand paper or scotchbrite pad is still the quickest and easiest way to prep the surface. If you lightly scuff it and wash it down with denatured alcohol, you should be all right!
Good Luck!
Good Luck!
3rdRock:
I appreciate the info. I guess I was considering compromising a good prep job for time saved. BTW, do you know if I can apply several coats of Herculiner to provide a thicker finish?
Jeff
Jeff
OE812,
You can apply several light coats of herculiner. I did the entire surface and then went back and applied a second and third coat to high traffic/ use areas such as the tailgate. I also took the tailgate access panel off of the truck and did it seperately in case I ever need to change the handle or lock.
1999 F-150 XLT Supercab Black factory stepbars Flareside Sport Package Oxford White Full tint - all windows. Bug Shield CD player 17" wheels, K&N Air Filter Ford Soft Tonneau Cover Gibson Super Truck "Did it myself" Undercoating Herculiner, Image Tailight Covers
Stereo Mods:
Clarion Pro Audio SRC5752s mounted in the front, tweeters mounted above arm rests.
Kenwood KFC-577Cs mounted in the rear doors.
All speakers installed with baffles behind them.
B-Quiet sound dampening installed in all doors, three layers on rear wall, and entire floor board done as well.
"Freak on a Leash"
If you've ever purchased online, please visit my new site and post your experience: Online purchasing experiences good and bad.
Click here to get a FREE Sample of the best Sound Dampening Product Ever!
Stereo Mods:
"Freak on a Leash"
Spyder207:
Thanks for the info. Your reference to Luling reminds me of when I go on vacation with my family to Disneyworld during Mardi Gras...I just can't get away from the locals!
Nice hearing from ya,
Jeff
2000 F-150 Supercab, White Paint, 5.4L, Auto, 3.30 rear; Only mods: bug deflector and rear seat head restraints.
Jeff
