Bedliners, Caps, Tops & Lids
Bedliners
Old Jan 26, 2000 | 09:13 PM
Fordtech's Avatar
Post Bedliners
Does anybody know of a good way to keep your box from rusting when using a bedliner?
What do you guys prefer: the Ford bedliner or an aftermarket bedliner?
Thanks!!!
1999 Ford F-150 Regular Cab Flareside with the Off-Road Package
Old Jan 26, 2000 | 09:17 PM
dirt bike dave's Avatar
Post
I went with the Ford mainly because it was convenient to have it installed before I picked the truck up, and I didn't have to hassle with taking it someplace else.
The aftermarket ones are cheaper, but the Ford one is thicker and not nearly as slippery when wet as the aftermarket one I had in my Ranger.
1999 XLT S/C, 4.2 V-6, auto, 3.55 rear, dark torreador red/harvest gold, bed liner, Sony 10 disc CD, Edelbrock IAS, K&N filter, Superchip
Old Jan 26, 2000 | 09:27 PM
rhino's Avatar
Post
Hi Fordtech,
No real way to keep the bed from rusting w/a drop in(they vibrate while driving,rubs the paint off),check out the spray-on liners in your area,they are getting vary popular(been around for about 12yrs).Spray-on liners have many advantages over drop in's
like-
no rust
non skid
lifetime warranty
color matching
best fit you can get(air tight)
increased resale value(NADA,Kelly Bluebook)
good luck
97 f150 xlt lariat Super cab,offroad
5.4L
4" Trailmaster lift
35x12.5x16.5 Bfg tires
Centerline rims
Smittybilt nerf bars
Rhino bedliner
fiberglass ram air hood
Warn 9000XDI winch w/semi hidden mount
Old Jan 26, 2000 | 09:59 PM
Dustoff's Avatar
Post
I went with an aftermarket bedliner strickly because of cost (I went to Ford and they wanted an additional $80.00)
I bought a Pendaliner, which is supposedly just like the FORD bedliner...same thickness, no logo. In fact, the place I bought mine installs different brands for all of the local dealerships...including FORD.
I guess it would be a good idea to take it out once a year to wash and wax the bed under the liner. When I took mine out of my 98 to put in my 2000...there was no rust, some very minor rubbing...no scratches.
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
[This message has been edited by Dustoff (edited 01-26-2000).]
Old Feb 1, 2000 | 11:24 AM
bunabayashi's Avatar
Post
Although I only recently purchased my F-150, in previous trucks, prior to installing the liner, I waxed the crap out of the bed, using a paste wax like Turtle Wax. I did *not* buff out the excess. It seemed to help substantially-- while it can't help eradicate wear spots, it absolutely helped keep trapped moisture from rusting.
Old Feb 1, 2000 | 05:50 PM
hobbit's Avatar
Post
I saw a product on "Shadetree Mechanic" specifically designed to go under plastic bed liners to protect the bed. I dont remember the name of the product or what it was made of, but Shadetree Mechanic has its' own web site you might be able to check there.
It's a place to look at least.
Hobbit
99 XLT,4.6L Auto,4X4,tow pkge,Factory Nerf Bars and Mudflaps, K&N filter,BugflectorII, Amazon Green/Silver, Pace Edwards Rolltop Cover, maybe a Superchip
Old Feb 9, 2000 | 08:31 PM
brocker's Avatar
Post
I have used a spray on product called LPS-3 to inhibit rust on just about anything. I just bought a truck and will apply this before the bed liner goes in. It is a relatively heavy wax based product that really sticks, but is removable if you work at it. It comes in three grades (LPS 1, LPS 2, and LPS 3). The LPS 1 is about like WD-40 in consistancy. Not much good for rust inhibitor. The consistancy gets heavier as the number increases. Get it at better hardware stores.
