Spark Plug Change on 2004-Early 2008 5.4 3V
Old Jun 3, 2011 | 01:08 PM
  #46
dos0711's Avatar
Don't suppose you have a picture of the two different boots?
Old Jun 3, 2011 | 01:11 PM
  #47
Good grief! They are the same, one is black, the other brown. Kind of like different colors of shoes. You know which one you have on when you look at them.
Old Jun 3, 2011 | 01:19 PM
  #48
bubbajoe28's Avatar
Originally Posted by 88racing
Here's the diff on the plugs....
Left is brown boot.....Right is black boot...
The left is considered a standard one piece design....traditional style
Can that new plug be used in our older 5.4's, or was there a new head design in 08?
Old Jun 3, 2011 | 01:20 PM
  #49
No, completely new head design.
Old Jun 3, 2011 | 01:37 PM
  #50
Just the way the spark plug holes are machined to accept the traditional spark plug design.....all the other components remain the same....
No more heat shield pocket...threads all the way...
Old Jun 3, 2011 | 01:39 PM
  #51
Brown boot....
Old Jun 3, 2011 | 01:40 PM
  #52
Right, but the new plug design will not thread into the old head design. As far as I know, if you had to replace heads, you could use the new head on a 2004-2007 engine.
Old Jun 3, 2011 | 01:45 PM
  #53
Correct....
The new plug also sits deeper in the plug hole and requires a different smaller size socket....
  #54
dos0711's Avatar
Thanks 88racing...THAT was helpful.
Old Jun 3, 2011 | 01:53 PM
  #55
He's quite the "brown" noser!
Old Jun 3, 2011 | 01:57 PM
  #56
Old Jun 3, 2011 | 01:59 PM
  #57
dos0711's Avatar
LOL....btw, does Motorcraft make a solid plug like the Champion?
Old Jun 3, 2011 | 04:02 PM
  #58
Nope...their cure is nickel anti sieze on the shank...not to bad of a way to keep carbon building up on the heat shield....if you have the lisle tool keep it for just in case...
IMO....use Motorcraft plugs....a lot better results...less headaches...
Old Jun 3, 2011 | 11:50 PM
  #59
That was very helpful though, I was always curious myself... thanks for that 88
Old Jun 4, 2011 | 12:58 AM
  #60
bubbajoe28's Avatar
88,
What is the recommended Motorcraft plug? SP507,sp515? Is that SP462 plug in your picture above used in the 5.4? It looks like the basket hoop is longer and less of the electrode shield is actually in the combustion chamber.
Bubba
