Center Console Sub Enclosure Build
Old Apr 22, 2009 | 10:02 AM
  #31
05_sprcrw's Avatar
Originally Posted by styxnpicks
man you shouldn't have dont the dound deadening with all those little strips like that. using big sheets is much better
Well I overlapped each strip, I guess I can always add big sheets over it. Why is it better to do big sheets?
Old Apr 23, 2009 | 04:24 PM
  #32
05_sprcrw's Avatar
Well I am hoping to test fit the sub this evening and get it prepped for paint. I will be painting it tomorrow evening. So I should have some more pictures soon for you guys. I want to have the system powered up by the end of the weekend, so hopefully all goes well and I can manage to get it all done. I will take more pics once I get the thing prepped for paint no point in showing almost the same pics. I am still waiting on the contact switches so I will wait to add the leds at a latter time. Thanks to everyone who responded with the sound dampener tips, I am sure it will help others who are looking into doing this themselves.
Old Apr 26, 2009 | 11:26 AM
  #33
05_sprcrw's Avatar
Ok guys I know I have let this thread die down a little bit, due to focusing on the build itself. Well I have some good news and some bad news!
The good news is I finished it last night and powered this thing up and all I can say is WOW! This sub blends perfectly with the music and you can not localize the driver at all. I already have had three people think that the mid basses were putting out all the bass
The bad news is that I forgot the my camera's link cable at work so I can not upload pictures until tomorrow. There are a few things I would like to maybe expand upon later on but for now I can say this build is complete!
Thanks for all your help, and input along the way guys you truely helped me install a first class sq setup!
Old Apr 27, 2009 | 09:44 AM
  #34
05_sprcrw's Avatar
Day: 14
Today I decided I would put everything together to make sure it all fit. I got everything test fitted in the garage and moved it into the truck.
Side views of what will be visible:
  #35
05_sprcrw's Avatar
It all checked out so I disassembled everything and set out to paint the box. Instead of sanding it silky smooth and then painting it, I decided I would rough it up and apply sound dampener inside and outside the box instead.
I had a little bit of Raamatt leftover from the back wall so I used that up. I also got the rear air delete cap attached as well.
Painting:
As a side note the paint stuck really well to the sound dampener.
Old Apr 27, 2009 | 09:45 AM
  #36
05_sprcrw's Avatar
Day: 15
Now that the paint has dried, I glued and screwed the plexiglass to the top of the box.
While that was drying I laid out the top console pieces and packed them with non hardening modeling clay to help reduce felt vibrations in the console. I used only about 10 lbs in the console, I will probably add more at a later date. I found that instead of working the modeling clay until it got soft that if you soak it in HOT tap water for about 30 min it will become a lot more workable and is a lot easier on the hands. I then packed the clay around the mounting base for the DIYMA to make a good seal, and help dampen the box from further vibrations.
Packing clay around the console:
  #37
05_sprcrw's Avatar
Once the glue was dry I started to assemble everything for the final time. I bolted it all back together added one more bracket to the rear of the box so I could bolt it down to the floor.
I dropped the DIYMA into its final resting place and tightened down the screws. I moved it out to the truck put it into place, soldered the connections together, and finally powered up the system………..
  #38
05_sprcrw's Avatar
And all I can say is this sub is by far the most translucent sub in existence! I am simply amazed at how well this thing blends and how accurate this sub is. It simply does not get better for a sq sub. (If you are local and want to hear it just let me know I will be more then happy to meet up with you)
And since I was bored and decided my D3 would need a good wallpaper to match up with the system I made it a new background:
Well that is all I have hopefully it inspired some of you to do something that may be outside your comfort level. I learned a lot through out the build of this and now am surrounded by complete musical bliss when I drive.
Final build specs are:
JL 500/1 v1 pushing a single DIYMA R12 in
a custom console enclosure with .5 ft^3
JL 300/4 v1 bridged pushing Diamond Audio Hex 6.0 speakers
Using the 5.0 crossovers with the silk tweets
KnuKoncpetz install accessories
Tech Flexed all wires
Pioneer Avic D3 dvd/navi hu
The big 4 re wire
Raamatt sound dampener.
Old Apr 27, 2009 | 10:07 AM
  #39
looks good! How much clearance do you have between the magnet and the pexi?
Old Apr 27, 2009 | 10:17 AM
  #40
05_sprcrw's Avatar
It approx 1" it looks really close though.
Old Apr 27, 2009 | 12:31 PM
  #41
bigdog87's Avatar
Looks AWESOME
Old Apr 27, 2009 | 01:59 PM
  #42
Jaderbutt's Avatar
WOW!!! What a great build! Thank you for taking the time to take pictures and post them on here!
Old Apr 27, 2009 | 02:03 PM
  #43
Steeda1996's Avatar
Looks good! I'll bet it sounds even better.
Old Apr 27, 2009 | 02:11 PM
  #44
05_sprcrw's Avatar
No prob and thank you
Thanks, and yes it does sound a lot better then the build looks.
Old Apr 27, 2009 | 02:16 PM
  #45
wick246's Avatar
Nice work! I was having a hard time picturing how it was all going to go together. Looks nice and out of the way. Glad it sounds great...
