Overhead Console Temp Display Repair
Old Jul 31, 2012 | 02:17 AM
  #121
jgger's Avatar
The "510 piece" is a 510 ohm resistor. Its a flat resistor, but you could use a barrel type in a pinch
several people have put in other resistors that were close, read through this whole thread, i think someone found one that was like a 530 maybe?
good luck.
Post #15 on the first page of this thread. I used the barrel type and it was a 480, still working fine today. I think I did the fix about a year ago.
Good luck
Old Aug 3, 2012 | 12:55 AM
  #122
Princess SprCrw's Avatar
Need some help
Originally Posted by jgger
Did mine today-really easy. The only problem I had was I lost one of the 510 resistors. Went to Radio Shack but all they had was 480, they said I could order the 510 but I called an electronic/computer guy I know and he said that the 480 will work fine. Had to fork out a whopping 99 cents for five of them. Stuck it back together and it works GREAT!! The only thing I would suggest different is to use an iron and not a gun to do the fix.
THANKS PATMAN!
I was trying to fix my Temp-compass and realized one of the 510 resistors was missing which is probably the reason mine is not working. I want to make sure when I go and ask for this I know exactly what to ask for, can you help me. I think sometime guys think girls can't do jobs like this, but I like to be as handy.
I have a black 03 F 150 super crew my beauty
Old Aug 3, 2012 | 01:12 AM
  #123
jgger's Avatar
What is ideal is another 510 resistor. The little square ones are probably impossible to find.
Go to Radio Shack and tell them you need a 510 ohm resistor, which they may or may not have. Like my post says I ended up with a 480 ohm, and it still works flawlessly.
The one they will have is what is called a barrel type. It looks like a little piece of straw or a dowel with a wire comming out of each end. Bend the wires so they lay across the contact points where the 510 was and soldier away. The wires will be a bit long so just trim them to fit your needs.
Like I said before they are inexpensive, I think like a buck for 3 of them.
Good luck.
Old Aug 10, 2012 | 07:42 PM
  #124
HHT Express's Avatar
This was one of the first threads I read when I found this forum and since I was having the same problem I figured I would follow the simple instructions and see if I could accomplish the task at hand. It took two tries. The first time I thought I had the problem solved but a few miles down the road and out it went again. Surmised that I needed to keep pressure on the resister while I soldered it. So far it is working as it should.
torn apart....
15 minutes later.....
Thanks Patman for starting this thread and sharing your knowledge.
Old Aug 10, 2012 | 09:54 PM
  #125
Takeda's Avatar
Good luck.
The original is called a SMT (surface mount technology) resistor. The "barrel" type resistor is actually called an axial lead resistor.
I found a similar problem with the radio in a Ranger several years ago. The radio would play ok, but the display would go out. The problem was bad solder joints:
http://bob-ayers.smugmug.com/Cars/Fo...7_9BJtR-X2.jpg
Before:
http://bob-ayers.smugmug.com/Cars/Fo...0_gAywv-X2.jpg
http://bob-ayers.smugmug.com/Cars/Fo...9_yTyoN-X2.jpg
After:
http://bob-ayers.smugmug.com/Cars/Fo...2_cC7qg-X2.jpg
http://bob-ayers.smugmug.com/Cars/Fo...0_B2zbK-X2.jpg
Last edited by Patman; Aug 10, 2012 at 10:03 PM. Reason: taking IMG tags off the large images
Old Aug 10, 2012 | 10:04 PM
  #126
Glad you got it!
Old Aug 10, 2012 | 10:06 PM
  #127
Takeda's Avatar
SMT Resistor Values
Some information on SMT resistor value marking:
In the case of the resistor with 510 The first 2 digits (5, and 1) are the resistor value, the third digit (0) is the X10 multiplication value. So, 510 is
a 51 ohm resistor. The resistors next to the 510 resistors, which are 101, are
100 ohm resistors 10, and 1X10 for the multiplication value.
Old Aug 11, 2012 | 02:17 AM
  #128
jgger's Avatar
I didn't know that....that is why I ALWAYS ask before I start messing with electrical stuff. Thanks.
Old Oct 5, 2012 | 07:25 PM
  #129
Roadie's Avatar
You Da Man Patman! Mine went dark recently after working intermittently for a while!
Thanks!!!
Old Oct 7, 2012 | 08:49 PM
  #130
GMrWizard's Avatar
Outstanding thread. Love it when people dig in and "repair" the part rather than replace it. I have the same issue with a 2002 F150. Will go out and get a soldering pencil tomorrow. Mine looks a little suspicious but cannot tell for sure. We will see.
I have seen a few questions about finding a wiring diagram for the console but never saw the answer. Anyone know where to find a wiring diagram? Maybe I missed it but any help would be appreciated.
Old Oct 8, 2012 | 10:01 PM
  #131
GMrWizard's Avatar
Found a good wiring diagram. Hope it helps anyone needing it.
http://www.justanswer.com/ford/39tnc...wire-head.html
Old Nov 28, 2012 | 03:26 PM
  #132
Johan1's Avatar
Dark console Solution THANKS
I dug this up searching for a reason my console stopped working and I had to join just to say thanks for the solution!!! Of course Ford would have replaced the board at an inflated labour rate, when it was only 10 minutes work to fix it.
Thanks so much for posting these idiot proof instructions. I will visit here from now on.
I am on my 4th Ford and I won't change now.
Old Dec 11, 2012 | 11:01 AM
  #133
itchibahn's Avatar
My 2003 F0150 Supercrew's overhead console, in addition to temp/compass, it also has lights on sides and moonroof button.
I removed the temp/compass controller board, and all solder joints look good with nothing unusual component. My guess is IC chip problem, but I cannot find any controller board for it. I checked ebay, googled, called local auto salvages, but no luck.
Someone told me these parts are not interchangeable, but looking at the photo of this initial thread, the PCB looks same as mine although the console casing is different.
So I'm assuming, as long as the model is 2003 F150, the inside PCB would be same even though the console casing are different? Could someone confirm, please?
Thanks.
Old Dec 11, 2012 | 12:27 PM
  #134
I'm sure the board itself is interchangeable, I doubt Ford would have a special board just for the limited production vehicles with the moon roof
Old Dec 11, 2012 | 01:47 PM
  #135
itchibahn's Avatar
Smile Got it Fixed !!!
I found an overhead console on eBay, and it claims it's for 1995-2012 FORD F150 that will work on my 2003. The console look exactly same as the photo on this initial thread, but the PCB looks different in shape.
Anyhow, I tested the PCB with my DVM, and I noticed there were two resistors intermittently reading different resistance. Although from visual inspection it looks fine, I re-soldered them and now they work fine.
Thanks to the original poster!!!
