PRND21 pointer fix
Old Nov 2, 2009 | 12:09 AM
PRND21 pointer fix
Are you tired of seeing your pointer in the wrong place, here's a quick fix for you
Look under the dash at the lower side of the steering column and you see this black adjuster
Pinch it and spin it until the pointer is in the correct place
It is tricky to find, i made a quick video to show the location to help clear up any confusion
http://www.youtube.com/watch?v=IDdGJZGo5a8
Old Nov 2, 2009 | 12:42 AM
b2therad's Avatar
Nice! Mine is broken for sure I think.. My park is actually pointing to the R. It broke out of no where one day when I shifted into park.. it just would not go all the way. It goes through all the gears fine but its just one over on all of them.. weird I know.
Old Nov 2, 2009 | 12:53 AM
take a peak under there, it may be a quick fix for you
Old Nov 2, 2009 | 12:57 AM
dirtyd88's Avatar
Never knew this. Thanks Patrick.
Old Nov 2, 2009 | 01:00 AM
b2therad's Avatar
Would that be the same gear that they tell you to adjust when you install a body lift? Im pretty sure it is. Ill try it tomorrow though.
Old Nov 2, 2009 | 12:05 PM
Not sure, ive never done a body lift before
Old Nov 2, 2009 | 12:39 PM
4.2trimble's Avatar
theres always time
but good info
Old Nov 2, 2009 | 06:28 PM
lil_bizzy's Avatar
Works great!
Old Nov 2, 2009 | 06:30 PM
Nice tip Pat... I don't have the problem but I've seen it before
Old Nov 3, 2009 | 01:14 AM
willys5555's Avatar
am i just blind or does my truck not have it...?
i have a 1997 and i have followed the cable all through there and i cant seem to find it anywhere...
Old Nov 3, 2009 | 02:30 AM
nonwoven29's Avatar
ot too try this and see if it helps
My selector always points too the right of the "P" ans some times doesnt start in the right of the "p" Ill try this tomorrow. Thanks for the cool info
Old Nov 3, 2009 | 01:08 PM
99green tribe's Avatar
cool thank you,
Old Nov 3, 2009 | 02:23 PM
AZTriton's Avatar
I've been procrastinating on fixing mine but you've taken the guess work out of it! Mine is WAY off. Great post!
Old Nov 3, 2009 | 06:39 PM
d4studmuf1n's Avatar
if it is alittle off, the adjustment will help, but if it is way if the little tabs are probly broken (a very common problem) only problem is you can buy the little white bracket you have to buy the whole freaking indicator..... 35 bucks i think (thats what i got mine for when i worked at ford)
Old Nov 3, 2009 | 06:47 PM
06yz250f's Avatar
exact same spot on the f250.
thanks pat.
