How to Clean MAF-2005 5.4
Old Jan 21, 2010 | 11:17 PM
  #31
Originally Posted by mackt
can you use anything else? like air intake cleaner or something like that that I might have laying around the shop or should I go buy that stuff specifically???
NO! Very important to use a cleaner that leaves no residue. Must be for cleaning electronics.
Old Jan 22, 2010 | 03:51 PM
  #32
wacp2's Avatar
where is the MAF in a 5.4L engine 2003
Old Jan 31, 2010 | 05:39 PM
  #33
mhockey9090's Avatar
I just did mine and when i started it up it felt better than before. Well see how it is when i drive it and im at a stop.
Thanks for the write up. Also cleaned my filter and the engine bay a little while i was at it.
Old Jan 31, 2010 | 05:56 PM
  #34
I'm not sure, but I think it is in the air tube near the filter.
You might post this question in the forum for 1999-2003.
Old Jan 31, 2010 | 06:00 PM
  #35
Hope it helps. Has always helped mine.
Old Jan 31, 2010 | 06:32 PM
  #36
How often do you do it?
Old Apr 30, 2010 | 04:53 AM
  #37
credurdead's Avatar
This is awesome, can't wait to tear into the MAF for a good cleaning...I am idling a bit rough at 65k
Old Apr 30, 2010 | 06:36 PM
  #38
credurdead's Avatar
Just got it apart and sprayed, really is as simple as the directions say, the guys at oreilly's auto didnt know if the CRC electronics cleaner was any different from the MAF cleaner, but it probably is all the same in the end just in a different can and for a few cents more because its a specialty solution. They could have sold it to me in a smaller can atleast....I'm never going to need to buy another can of this stuff for the rest of my life. Might even start passing it on as a family heirloom the can is so big.
Old Apr 30, 2010 | 08:53 PM
  #39
fine_style150's Avatar
depends on how often you maintain your truck in this area of the engine...im pretty delicate and perfect, and grown accustomed to have my truck running smooth on idle and like bluejay im in the habit of doing this every 3000 miles.....err every oil change, plus she runs like new everytime i do it, so maybe ill end up needing two cans for my lifespan...
Old May 10, 2010 | 04:44 PM
  #40
x2mosg's Avatar
Just cleaned mine on Saturday. Truck was idling rough at low rpms, like around 550-600, before and now idles smooth at around 700 rpms. I'm hoping to see a MPG improvement. I've been gettinga about 12.5-13 with stock tires, DWV intake mod and dual exhaust. Hoping this improves upon that.
Thanks for the write-up. Easy as can be maintainance. Think I'll hit mine again this next weekend, just to be sure I got all the build-up off the contacts.
David Walker
Old Jun 7, 2010 | 09:44 AM
  #41
BeauFlex's Avatar
Thanks Bluejay.
just reached 50k on the 06. noticed it had started "stumbling" a bit at WOT. also when cruising the truck would shift in & out of OD constantly.
This seems to have helped these issues so far.
Old Jun 26, 2010 | 09:06 PM
  #42
Fordoor's Avatar
Thanks for the article.
Did mine today.
Took 5 minutes,not including the drive to Pepboys.
Best 7.99 I EVER spent !!
Old Jun 27, 2010 | 02:13 AM
  #43
Glad to hear it! Always feels good when someone makes use of a How To and it turns out good.
Old Jun 28, 2010 | 11:49 PM
  #44
southern2003fx4's Avatar
i cleaned my MAF an 30 mins after cleaning check engine light came on read MAF low in put. it was kinda wanting 2 die when i would stab the pedal. went back the connection was loose after i tightend back up it runs fine now. will the engine light go off? or should i get it turned off?
Old Jun 28, 2010 | 11:57 PM
  #45
You will need to clear the code with a programmer if you have one or just disconnect the battery for about 15 minutes.
