New method to extract porcelain from broken spark plugs
Old 11-12-2008, 02:46 PM
Tylus's Avatar
this should be a DIY or a Sticky.
about what? $10 in parts vs the $100+ rotunda tool
good job
Old 11-12-2008, 02:53 PM
good job
Good suggestion, it now has a sticky.
Old 11-17-2008, 08:38 PM
compmastr's Avatar
Angry
Originally Posted by FX4_2003
seeing what a pain in the butt it is to change plugs out I wonder if it would be worth it to have a mechanic do it.. and do you really think a mechanic would change all of them out ?? I am to scared to touch mine, (5.4 v8) heck I cant even see them..
I decided to let the dealership do mine at 75,000 miles when my 04 developed a miss. I got my truck back today along with a $1007 bill. $141 for cost of plugs, $74 for a bad coil, and $735 for 10.5 hours labor including extraction of 6 broken plugs. I didn't think I'd have to pay that given the TSB that is out, but they told me Ford says to charge every hour to customer!
Old 11-17-2008, 10:20 PM
princejo's Avatar
I was always under the impression that you pay the book rate for scheduled services--i.e. a flat rate for a 75k service. Does this vary across dealerships?
BTW--that's some nice work on putting all that together!
Old 11-18-2008, 06:01 PM
TSB's are not recalls, or free work. TSB stands for technical service bulletin, which just means it is a guide line to work by. Its basically a fancy how to sheet for the technicians, that is recommended from Ford.
Other then that, great posting OP way to be inventive
Old 11-19-2008, 06:26 PM
xxs0ulxx's Avatar
Question
should i be worried? my truck is a 98 with 130000 miles on it.. never had a broken plug. i have changed em out once... when i bought it at 98000 miles... i put 100k plugs in it.. think they will break>???
Old 11-19-2008, 08:04 PM
Rockpick's Avatar
Moderator &
The broken plug problem was a 2004-2006 problem.
Old 11-20-2008, 10:06 AM
tg150's Avatar
Heres a thread tha may help you.. Goodluck
https://www.f150online.com/forums/20...-pictures.html
Old 11-23-2008, 11:11 PM
yetti96's Avatar
I just got mine changed Friday (11-21-08) on my 2004 5.4L with ~43k miles. No penetrating liquid was used an none broke. I was very surprised and pleased to have all 8 come out in their entirety. I also put the Champion, 1-piece plugs back in to prevent breakage in the future.
Old 11-28-2008, 08:02 AM
ryan42680's Avatar
There's been so many stories on the plugs, mostly that the temperature rating is no good for a plug with a shield, or whatever the actual problem with the plugs was.
I have, however, been to 4 dealerships in New England, and after asking questions, I have always gotten the same exact answer. I've been told the plugs were essentially too long. Not so much noticably by looking at them, but just long enough (maybe less than millimeters) that they would "bottom out" in the head and sieze up right away. And the build up of carbon over time was no help. So Ford knew about it all along and did noting until recently, I was told. 2008 models built after a particular date (not sure what it was) are supposedly all set. The plug is not only a different temp, but a tiny bit shorter, allowing clearance so it will not bottom out. And from what each dealer has told me, my truck with a build date of August '08 is all set. I want to believe this, especially because it's several dealers giving me the same story, not just one tech or service manager trying to give me a simple wrong answer.
Old 12-03-2008, 11:03 AM
jloyd@hardric.c's Avatar
Good info. I have an 04 and just had them changed by a dealer. The mechanic is a good friend, and he used an impact wrench to extract the plugs. all 8 came out clean.
Old 12-10-2008, 03:29 PM
screw_firstdate's Avatar
Originally Posted by tylus
this should be a diy or a sticky.
About what? $10 in parts vs the $100+ rotunda tool
good job
x2!
Old 12-11-2008, 09:29 PM
Wingo's Avatar
Angry 49 days in the shop
Took my 2005 f150 to the shop with a check engine light. Had an extended warranty with $100 deductible, so I took it in. Bad #8 coil and they wanted to change the plug. With 82K on the other plugs I wanted to change the rest. They broke three off including the #8 cylinder that had the miss. I got the truck back and noticed a high rpm rattle. Check engine light came back on. After a week of codes going active and inactive they determined the exhaust valve was sticking on the #8 cylinder causing a rich condition on that bank of cylinders. Removed cab and head, rebuilt valves and returned truck. When I picked it up it had a rough idle when cold. Check engine light came back on, cylinder misfire #8. They put new valve springs and replaced cats with no results. They then said they didn't know what was wrong and needed a Ford engineer. The engineer told them to remove the head again, so off with the cab for the second time. Here I sit two truck payments later waiting on the engineer to make a call.
My costs $752, warranty paided $3200, looks like the dealership is working with Ford for the last valve springs, cats, and latest teardown. Expensive plug job!!!
Old 12-14-2008, 08:02 PM
frank 05 f-150's Avatar
again broken plugs on 05 f-150
i have four broken plugs on a 05 f-150 crew cab, 5.4 3v triton engine, the fact is the electrode, the half porcelain and the electrode still in the head, so i canīt remove the porcelain center, just the nut and the upper porcelain half came out.... so, any idea how i can do the job with out taking out the heads? thank you
Old 12-14-2008, 08:14 PM
You need to read the OP's first post, it's all right there.
Quick Reply: New method to extract porcelain from broken spark plugs
