Cleaning the Throttle Body
Old Jan 15, 2008 | 10:26 AM
R1Jester's Avatar
sludge resistant coating??? Maybe in the newer ones but I can tell you mine(2000) was caked with sludge!
Old Jan 15, 2008 | 10:31 AM
Green_98's Avatar
a lot of good their 'sludge resistant coating' did. HA! My throttle body ports were plugged closed the first time I cleaned mine. Ford suggests to use only 'throttle body cleaner' when doing the thottle body so that the protective coating will not be removed.
I used like 4 cans of carb cleaner and a parts washer the 3 times Ive done mine
Old Jan 15, 2008 | 10:58 AM
jbrew's Avatar
I got a new throttle body pic in my gallery with that anti-sludge coating stuff on it. If I ever end up using it , the first thing I will do is stick a wire wheel in there and remove it. Then polish it - they stay cleaner longer without it. If you don't maintain your vehicle well - then leave it in..It keeps your Throttle Plate from getting gummed up - Well, that's the intention.
Old Jan 15, 2008 | 11:03 AM
cdnance's Avatar
yeah it is supposed to be on there, but it works about as good as a one legged man in an *** kicking contest. i cleaned mine on my 97 and i could tell a big differance at stoplights and cold starts especially.
Old Jan 15, 2008 | 11:47 AM
jbrew's Avatar
Anti- Sludge coating -
That's what it looks like - That's a new TB and Plenum from a 4.6L Crown Vic 65mm From the Romeo Plant.
Old Feb 1, 2008 | 09:54 AM
aaks38's Avatar
new gaskets needed
Guys, im about to clean the ISC, EGR and throttle body assembly, can you reuse the existing gaskets or need new ones?
Thanks Cal
Old Feb 2, 2008 | 09:15 PM
Delirium's Avatar
Isc?
What is the ISC and the IAC and how do you clean them?
Old Feb 10, 2008 | 10:20 AM
NHguy's Avatar
I used to work for a company that sold this sort of product and service, we cleaned off the coatings every time and got great results. The protective coating does no good once it is sludged up.
BTW if you can find a place that does BG products that's who I was with, it REALLY works. Takes under an our and costs probably $129. I cleans the intake, throttle body, plenum, rail, injectors, fuel pump and delivery system, combustion chambers, valves, and also improves catalyst efficiency. Not only do you get a clean TB you get more power because the combustion chambers are de-carb'ed. This brings your compression back down where it belongs. This in turn allows complete combustion by removing the preignition that occurs if the combustion chambers are gunked. In dirty engines when this occurs the knock sensor pulls back the timing which slows you down and wastes gas.
check www.bgprod.com, or www.bgfindashop.com. I swear I don't work there now. Pete
Old Feb 11, 2008 | 02:54 PM
Drobinson6969's Avatar
I just cleaned my TB and I did not remove it fromt he engine. I dont notice anything in change? Would it be better if i took it off to clean it or does it really not matter?
Old Feb 11, 2008 | 03:19 PM
jbrew's Avatar
- There's a little more to it than that.
Cleanining the TB involves removing the plenum - it's all here in the stickies - links as well . - just look and read.
Old Feb 17, 2008 | 05:20 PM
Req's Avatar
Req
My local Ford Dealership ran a Special on injector, throttle bottle, cylinder clean out for $57.45. Although I did not need it with my low mileage on my '04 RCab, 5.4, I was first in line. Could not do this at home as good as the Dealership nor in the one hour they had my rig, plus shuttle service.
But those of you who did the throttle bottle clean up and posted pictures it is a great help to those who really want to know how the throttle body plays into the air intake of an engine.
Old Feb 17, 2008 | 10:28 PM
jbrew's Avatar
Yea , okay
Old Feb 20, 2008 | 04:26 PM
Dans4x4F150's Avatar
anyone eber put a oil catch can on these things?
Old Feb 20, 2008 | 06:57 PM
jbrew's Avatar
I have one of those under the barbecue
Old Feb 21, 2008 | 09:26 PM
Boogerburns's Avatar
Wink
anyone know the procedure for a 91 f150 intake cleaning? its in the tranny shop right now. BUT you know what, it was neglected like crazy before i bought it and im cleaning (no pun intended) up after them. any advice/information would greatly be appreciated
