HELP! Please...
Old Sep 2, 2002 | 03:34 PM
4X4PWR's Avatar
HELP! Dash Surround. Please...
I am trying to take off my dash in order to get to my dash cluster but I am having a bit of a problem. I am unable to take off the dash piece that goes around the guage clusters.
I think this is because I am supposed to take off the headlight switch somehow... Does anyone know how? I have a 1998. I am able to turn the light switch to the "on" position and pull up, however it only pulls up to the fog light position. Does anyone have any ideas?
I dont want to break anything at all. So I will wait for your guys reply.
Thanks for saving me once again in advance!
Old Sep 2, 2002 | 04:26 PM
harleyrules's Avatar
1. Turn headlight switch all the way to the right.
*** Removal of this piece requires that the switch be rotated past its natural stop position.
2. Remove & reinstall the **** up side down and continue to turn to the right. The switch will disengage
I think that is how it works on a 98.
On my 2000 I did not need to remove the **** at all. The whole switch housing pops out with a little prying with a screw driver. Check your switch and see if you have a same slot on the bottom, if so pop it out with the screw driver method.
Old Sep 2, 2002 | 04:36 PM
4X4PWR's Avatar
No screw driver method..
My year does not have the screw driver method... I am kind of leary of turning it past its normal stop position. I defiantly do not want to break the switch!
Have you done this personally?
Sorry, im just scared of breaking anything.
Old Sep 2, 2002 | 04:41 PM
I have not done the first method. I got those directions from
tampasvt@tampabay.rr.com when I purchased my carbon fiber dash from him. You can email him for more info on this. Rich is a nice guy and I am sure he will help you.
Old Sep 2, 2002 | 07:56 PM
rbjones21's Avatar
Talking More help
If you can't get directions let me know and I got the Haynes and it tells the whole procedure and has pictures. I can send you it if needed.
Old Sep 2, 2002 | 08:55 PM
Ed S's Avatar
Had the cluster out of my 97 recently, 97-8 are identical...
What I did was to pull the L side of the large cover. With it out slightly, I inserted a screwdriver to push in & disengage the lever that holds the switch in. Popped right out, giving access to the screw below it. Now that I think about it, a putty knife would've worked easier than the screwdriver!
Old Sep 3, 2002 | 04:25 AM
4X4PWR's Avatar
RBJones...
If you could please email the instructions with pictures when you have time to kendall@sledtalk.com I would appreciate it.
Thanks a bunch fellas.
