Removing Blue Oval From Grill
Old Nov 11, 2001 | 05:50 PM
T Ellenberger's Avatar
I have a 97 XLT and want to remove the Ford Blue Oval from the center of the grill. I am trying to create my own design without tearing out the old grill.
I can feel the posts behind the Blue Oval. Are these threads or just slide on clips holding the Blue Oval?
Old Nov 11, 2001 | 06:14 PM
RAM AIR's Avatar
Two little nuts hold that emblem on. There small, can't remember the size. 1/4 drive with a small extension. Takes a minute to get them off. Take your shroud cover off an you can your hand down in there.
Old Nov 12, 2001 | 09:55 AM
F-150 Ram Air
Thanks for the info. I will play with it later today after I clean it up. I am attepting to create a grill and then put the Blue Oval back but, off center just to be different.
Old Nov 12, 2001 | 12:13 PM
sagittarius's Avatar
The nuts holding the oval in the grill are the cheap stamped type of nut. Should come off easy with a standard depth, metric socket, don't remember the size. I do remember reversing the nuts to reattach the oval to my Stull grill. You'll understand when you see the nuts.
Old Nov 13, 2001 | 09:49 AM
Since I have the XLT (not the egg crate grill) I was tempted to take my Sawzall and cut out the center section of the grill.
I plan to cover that part up with my home made piece anyway.
